Topic: what cable (PINs) do i need to buy for FF800 FW800
Hi folks,
does anybody know, what cable do i need to buy? I am using i-mac-27 that has firewire800 9-pin input, but how much pins has firewire800 input of Fireface800?
Re: what cable (PINs) do i need to buy for FF800 FW800
Same.
3 (edited by bori4 2012-05-30 21:53:47)
Jeff wrote:
Same.
Thanks a lot for the fast answer!
Could you please answer, is thear any difference between cheap FW 9pin cable , and for example original fw800 9pin cable?
Your iMac and your Fireface 800 both have Firewire 800 ports so buy a good quality FW800 to FW800 cable. The IEEE 1394 specification recommends 4.5 metres maximum length ( 14'-9" ). Your local pro audio dealer or Mac store should have this cable in stock
best regards,
Blair Francey
Fireface 802/ARC USB; HDSP Multiface x 2; 2023 AMD Windows 10 Custom PC
Cheap analog cable will still deliver audible audio. Cheap digital cable can only drop data sad
best regards,
Blair Francey
Thanks guys, i have bought belkin cable FW 800 9PIN TO 9PIN 6ft.(1.8m).
Thank you !
Boris
