Topic: Babyface - strange noises on power on / start up
Sometimes I am getting strange low frequency modulated noises when powering on the Babyface. It is very loud, going out through the phones/3-4 outs, this loud that I am afraid of headphones connected could get damaged.
It happens when powering on the computer with Babyface connected directly to it and also with some hub between, and not always, just sometimes. It occurs also sometimes when just hot plugging in the Babyface on running System.
What helps is to plug it out and back in, sometimes in the different outlet of the computer or the hub. It is macbook pro unibody 2011, although it doesn't seem to be the computer issue - it happens also with the usb hub. And no other device have a problem with my usb setup.
Looks like there is no rule when it happens. I can't say if the noise is coming also through the main outs, the speakers are of when I am powering on.
Does anyone else have this issue?
I have current firmware / drivers installed.
Thanks,
all the best
/memor
