Topic: FF400 + Radial Pro DI - correct connections for bass recording.
Hi, All!
I got Radial Pro DI for recording Bass DI along with miking the cabinet. http://www.radialeng.com/r2011/prodi.php
Everything seems simple but I hesitate about right connections. I plan to record passive basses with low output, this means that I need instrument level inputs. DI Box has a balanced output with 630 Ohms impedance. It's said in manual: "The instrument input operates servo-balanced, thus handles balanced signals correctly as well." As far as I understand I need to use this inputs for bass recording in instrument mode as they handle balanced signals even at instrumental level of sensitivity, right?
Thanks,
Nick
