Topic: Fireface 400 Driver install error
Hi there, I am a new user to the forum. I researched extensively the issue I am encountering but I found no solution in the forum or online.
my fireface 400 is not recognised by my both my computers. at the moment I am trying to connect it with:
Macbook Pro 15-inch 2.4/2.2GHz
Software Mac OS X Lion 10.7.4 (11E53)
Memory 2 GB 667 MHz DDR2 SDRAM
It was working absolutely fine before but I haven't used it after installing OS X Lion. I have the same problem with a new iMac 21 inches with these specs:
iMac Mid 2011 21.5 inches
Processor 2.5 GHz Intel Core i5
Memory 4 GB 1333 MHz DDR3
Graphics AMD Radeon HD 6750M 512 MB
Software Mac OS X Lion 10.7.3 (11D50b)
• Chipset: Revision ID: 0900000 (i followed instructions on this forum and I got that number via terminal)
on both machines under system profiler > Firewire I have this:
"Maximum Speed: Up to 800 Mb/sec"
in System Preferences > Network > Firewire it says "Status: Not Connected"
On the imac where i had the drivers previously installed they don't launch anymore.
On the fireface the Red light next to "HOST" is on constantly.
I used two different firewire cables since the machines ports are different. Ones is 400 to 400 (MacBook Pro) and 800 to 400 (iMac)
the drivers (Fireface_312_x86) installed successfully on both machines but when I launch the Fireface Flash update (171 277) it gives me a window with this message:
"Error No Fireface Driver or device installed"
Any help or advice in solving this issue would be greatly appreciated. As you can imagine I am getting increasingly worried.
Thank you in advance for your time.
