1 (edited by DanRand 2012-12-18 14:39:35)
Topic: Fireface UFX - Compatibility with Little Bustard Summing Mixer
I am looking to add a Thermionic Culture Little Bustard summing mixer to the outputs/inputs of a Fireface UCX, with the outputs of the Little Bustard coming back into the UCX.
The Little Bustard summing mixer is unbalanced with pins 1 & 3 tied to ground on both the inputs and outputs.
Can anyone tell me if the inputs and outputs on the UCX are compatible with the Little Bustard?  Will tying pins 1 & 3 to ground on both inputs and outputs cause any damage to the UCX?  Am I likely to get any level loss?  Or noise/hum?
Also, will standard BALANCED 1/4 inch jack to XLR cables be OK?
I hope you can help me.  I'm a little confused about the whole balanced/unbalanced, pins 1 & 3 tied to ground thing!!
Thanks,
Danno
Logic 10.7.2 - macOS Monterey 12.7.5
HDSPe Digiface via ExpressCard Adapter
Fireface UFX III & UCX I
2 (edited by MichaelPatrick 2012-12-19 14:46:35)
Re: Fireface UFX - Compatibility with Little Bustard Summing Mixer
The manual says:
The Fireface has eight balanced Line inputs as 1/4" TRS jacks on the back of the unit. The electronic input stage is built in a servo balanced design which handles unbalanced (mono jacks) and balanced (stereo jacks) correctly, automatically adjusting the level reference. (p40)
The short circuit protected, low impedance line outputs of channels 3 to 8 are available as 1/4" TRS jacks on the back of the unit. The electronic output stage is built in a servo balanced design which handles unbalanced (mono jacks) and balanced (stereo jacks) correctly. (p41)
Thanks for that Michael.
From that, I think I can conclude that the Little Bustard won't damage the UCX's output stage.
But I'm still not sure whether I'll get any level loss.  And which cables I should use.
4 (edited by isaac 2012-12-20 06:49:24)
MichaelPatrick wrote:
The manual says:
So yes it compensates and yes mono jacks are fine.
Isaac P
5 (edited by DanRand 2012-12-20 15:17:31)
Sorry, should have been more clear.
I'm referring to level loss on the balanced outputs, due to the unbalanced XLR inputs on the Bustard having pins 1 & 3 tied to ground.
Also, the Little Bustard only has unbalanced XLR inputs.  How would I wire mono jacks to an unbalanced XLR, remembering that pins 1 & 3 are tied to ground?  I thought I could just use balanced TRS to XLR from the UCX's outputs?
When the manual refers to short circuit protected, does that refer to situations such as where pins 1 & 3 are tied to ground on the Bustard?
A little confused...
Thanks.
