Topic: DIGICheck 0.661 Not Working
Since upgrading to OS X 10.7.5 and Logic Pro 9.1.8 about a month ago, DIGICheck is no longer working. Please see screenshot below:
As you can see, the TotalMix meters are working fine, but the DIGICheck meter isn't moving.
Just after upgrading to OS X 10.7.5 and Logic Pro 9.1.8, I also installed a Fireface UFX for a couple of weeks whilst working at a studio. So either the upgrade to OS X 10.7.5, or the upgrade to Logic Pro 9.1.8, or the installation of the UFX, or a combination of these factors seems to have made DICICheck stop working. The UFX is now gone and I've since removed all applications and .kext files for the UFX, but this has made no difference to DIGICheck.
I've also tried removing and re-installing DIGICheck.
Also, at the same time as DIGICheck stopped working, this problem also started: Digiface HDSPe Settings - Sample Rate Not Changing. I don't know if these problems are related.
Can anyone help?
Thanks,
Danno
HDSPe Digiface via ExpressCard Adapter
Fireface UFX III & UCX I
