Topic: flashin g lights on M32 AD as well cant get remote control via midi
Hi I have the M-32da as well the M-32AD both in use with Madi via the fiber optics. My M-32 ad sometimes the Level display when not in use lights will randomly start flashing on the bottom of the display. The unit works fine and if i hit any key the flashing stops as well if i start to use it the flashing stops. Just wondering what this was posable a screen saver or a sleep mode, over heat warning, OR sign of a problem starting, the other unit does not do it. Any Ideas.
one other question I cant seem to get midi over madi to work the remote control well the other way around the remote control using midi over madi will not control either units. there is no direct midi cable set up, just the fiber optics im thinking that midi over madi is usable this way or do i need a hard midi cable set up. Or am i missing a driver. Card is the Hdspe
