Topic: TMS (FF settings) is changing sound of Spdif-Input
In FF settings TMS is activated by default.
Now I´ve got a new Line6 Pod HD at the Spdif-input of my FF800. It sounds much thinner compared to using the analog inputs of the FF with the Pod.
After then I´ve deactivated TMS in the FF settings and now it sounds the same and as it should.
What is TMS ? For what purpose? Please give an example. Why is it activated by default and why do other audio interfaces (such as Roland Quad Capture) have not such a setting?
Isn´t it a bug that it changes the sound???
I used to play a Line6 Pod X3 through the Spdif-input of the FF before and TMS was activated all the time. I´ve tested it by recording: There is no or at least not such a big difference with TMS checked or unchecked compared to using the new Line6 Pod HD.
So this is very strange. Please help and explain! Thanks.
