Topic: Fireface UFX - Can't change Submix volume from front-panel
Just bought a brand new Fireface UFX from the store. While trying to adjust the submix volume (for example, adjusting Input 1 volume routed to Analog output 1), I can't adjust the Volume or Pan from the front panel/LCD. I can do it from TotalMix just fine. For the AN 3/4 Output for example, I scroll down and find Analog 1 Volume, select it with Button #2, but then can't change it from -Inf. If I adjust it in TotalMix, the value updates in the front-panel.
Is this expected?
Using latest drivers, Windows 7, Firewire 400.
