Topic: FF400: playback issue when changing samplerates
I'm currently building up my 'high end' Audio PC configuration. As soundcard and DAC I'm using the RME FF400. When I was testing a beta version of excellent JPLAY sw player I noticed problems in case music files with different samplerates/bitdepth were played after each other. Ok JPLAY V5 is still a beta version. So I used foobar2000 and similar problems occured. In the following I describe my experience with foobar2000 only.
I have a playlist with files of different bitdepth and samplerate (16/44,1 | 24.96 | 24.192). When a change of bitdepth/samplerate shall take place the playback stops. I have the FF setting dialog box open in parallel and can see that samplerate is changed correctly.
Solutions:
1) in such a situation I need to press stop button within foobar and select the file for playback again
2) stopping playback, manually selecting the samplerate within FF settings dialog, wait 1-2sec and select the file for playback
3) select a file for playback (with a different samplerate), press stop and play again
It seems that changing the bitdepth/samplerate takes some time within the FF400. Does anyone experience the same problem with foobar2000 or any other sw player?
@RME support: is this a known bug of FF400? What is your recommended solution?
KR
Peter
Config:
PC: Asus P8Z77-M | i5-3570K | Crucial Ballistix Tactical 8GB 1600 CL9 | Win8
RME: FF400 | HW 1.71 | Driver 3.070 |
