Topic: UFX / TotalMix FX: Loopback Problem
I'm trying to get a simple loopback working but I'm missing something here. I have used the loopback functionality before but now I just can't get it to work.
Example:
- Output 3/4 submix is getting signal
- Enable Loopback for Output 3/4
- At this point I should see the same signal at Input 3/4 but there is no signal (same goes for all other output/input pairs)
What could be the issue? Have I disabled the loopback functionality somehow? Loose cable inside the unit?
Edit: I'm using Windows 7 64bit. I updated the drivers and reinstalled firmware to see if that would help but it didn't. Also, I did Total Reset for TotalMix without success.
