Topic: hdsp9632 24 bit 96000khz missing outputs
hi i usually work at 24 bit 44100khz i use all analog outputs when i change to 96000khz i miss some outputs this is normal??
hdsp 9632 pci
aio192 enpansion card
thx
RME User Forum → HDSP(e) series → hdsp9632 24 bit 96000khz missing outputs
hdsp 9632 pci
thx
Yes, you lose the ADAT channels at higher sample rates.
ok at higher sample rates i just can use 2 of the 4 aio192 expansion card outputs??is that right??
i dont use digital outputs just analog
thx
No, all channels of the AIO expansion card are still available.
[img align=L]https://www.dropbox.com/s/9wwhoyox9qxmji8/2013-03-06%2023.05.57.jpg?m[/img]
at 44100khz
[img align=L]https://www.dropbox.com/s/lakeph7pibojojg/2013-03-06%2023.05.16.jpg?m[/img]
at 96000khz
i loose a5/6 and a7/8 outputs of the aio192 expansion analog outputs
https://www.dropbox.com/s/9wwhoyox9qxmj … 5.57.jpg?m
at 44100khz
https://www.dropbox.com/s/lakeph7pibojo … 5.16.jpg?m
at 96000khz
Those are the ADAT (optical) channels. Which expansion card exactly are you referring to? There does not seem to be an AO4S-192 AIO output card installed in your screen shots.
Everything looks normal. As Jeff said, there does not seem to be an AO4S installed, because that would show up in the mixer as additional channels. If you are referring to the older AEB expansion boards, these do not support 96k at all.
ok my expansion card is aeb 4 output that s why i miss channells at 96000
thx for the help
No, you don't "miss channels". The number of ADAT channels is reduced to 4, and whatever may come out of the AEB will not be a correct signal, so you can not use it... It only works up to 48k.
