Hi jeff
Cheers for the drivers , i installed them and got the blue screen again with error message
A problem has been detected and windows has been shut down to prevent damage
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to be sure you have adequate disk space. If a driver is Identified in the stop message, disable the driver or check with manufacturer for driver updates. Try changing video adapters.
Check with your hardware vendor for and BIOS updates.disable BIOS memory options such as caching or shadowing. If u need to use safe mode to remove or disable components, restart your computer, pressf8 to select advanced startup options, and then select safe mode.
Technical info
. Stop: 0x000007e (0xc0000005, 0x90812e2ef, 0x8a45a888, 0x8a45a460)
Digi96.sys-address 90812e2ef base at 90811000, datestamp 42dfd37d
Collecting data for crash dump
Initialising disk for crash dump
Beginning dump of physical memory
Dumping physical memory to disk: 100
Physical memory dump complete
Contact your system admin or technical support group for further assistance
Any thoughts
As i am just about to rip out soundcard and buy new one
