Topic: FF800 to ADI-4 DD to TC sync problem
Im having sync problem with this setup:
Macpro running 10.8 and Logic
FF800
This works fine!
But I want to use my TC effects in Logic.
So I connect from FF800 ADAT1 out to ADI-4 DD ADAT1 in.
On ADI-4 DD I use the D 25 split AES/EBU cable to TC M2000 and TC Fireworx.
The TC effects audio bus works in Logic but the audio clicks and the lights on the ADI-4 DD (Input state) starts to flash (stable for a while the flash.
FF800 is set to master. The sync on ADI-4 DD is on ADAT and AES state is PRO. The TCs have AES/EBU as sync source.
I have tried to use BNC WC from FF800 to ADI-4 DD (Input state WC, terminated) but the same problem!
After changing cables and all combinations of settings, logic and crazy! Im out of ideas.
Please if anyone have an idea whats wrong, Im going crazy
Thanks from Jonas
