Topic: ADI-2 Noise on D/A output
Hello everybody.
Recently, I got used rme adi-2 mainly for mixing down from my analog board.
First I was having some sample rate mismatch problem that im still trying to fix, I can only use 32khz without streatching sthe sample, but that is robably soundcard settings, software issue.
Another problem occured when i tried to insert hardware eq to my stereomix (cubase -> m-audio audiophile soundcard -> via spdif - adi-2 d/a -> hardware eq -> adi-2 a/d via spdif ->m-audio card -> back to cubase
Insted of eq'd stereo signal, i got some nasty noise. I found the noise comes out of the d/a converter. Its a loud high pitch noise, some of the original signal comes through it, but very little.
I was suspecting my diy spdif breakout cable between soundcard and adi-2, I have resoldered it but no change, Im not a soldering master, but it looked fine.
Im getting thoughts that d/a conversters may be damaged...I really hope that its something else...
I try to link samples, so you can hear how it sounds like. Do you know any sites for uploading mp3's that allow steaming (so you dont have to download it)
I hope someone will help...
thank you
