Topic: RME DIGI 96/8PAD with AEB4-0 PROBLEM
Hello i bought the expansion board AEB4-O for my DIGI96/8/PAD and the problem is the following
when i put the headphones to one of the 4 balanced outs the volume was in certain level and could not operate its level within the control panel.The same symptom while place the jack in out 2.The other 2 output pots remain silenced and no sound come out even if i choose channel 5/6 or 7/8 or 1/2 3/4.Can someone explain me what to do?Maybe the card is damaged.
My settings within the control panel are the following:
input: analog
output: automatic
stereo devices: sync allign
Safe mode: unchecked
output format: Force adat
Clocksync: Auto or master
My rme digi96 card has the adat boot jumper pulled
please someone who can help with the jumper settings on both cards, i read manuals but not understand it exactly.thanks
Below are 3 image links to check the jampers from both cards.Thank you!
s1083.photobucket.com/user/Jimarmaos/media/RME%20DIGI96/DSC02311.jpg.html?sort=3&o=0
