Topic: Two Firefaces and MIDI Control
Hello there!
I have an UCX and UFX linked via ADAT and want to use the big one as my main mixer. Simple MIDI control of some Input channels. With the UCX this worked like a charm. But the UFX is kind of difficult to setup. I have two TotalMix FX windows open - the small reacts the other not. Also I think I have found a kind of bug: When selecting in the settings dialog which MIDI In Port it's listing both Firefaces with the same name. When I select the last one and press ok the next time opening the dialog it's always the first selected. Maybe the cards should themselves register to windows as UCX/UFX and not "Fireface".
The manual is kind of cryptic regarding Midi control (not Mackie HUI!). When I edit the channel layout and disable M1-4 for some channels, does that mean the counting of which CC and channel to which Fader changes too?
With best regards
El Duderino
