Topic: TMFX Bug? Selecting an un-programmed Mix Snapshot & Main Volume Level
Hello all,
I noticed something odd yesterday. I have TMFX (MADIface-XT) setup to "Do Not load Main Volume/Balance". I saved valid Mix Snapshots in slots 1-4. I clicked on "Mix 5" and it seemed to load a default snapshot with a different (default) Main Out assignment (no problem, and expected).
When I re-selected my "Mix 1" snapshot, the Main Outs re-routed to match the snapshot, and the Main volume jumped to 0dB unity gain. Luckily I didn't have anything playing at the time.
This seems to stem from recalling a snapshot with a different Main Output routing and then swapping back to another snapshot with the desired Main Output routing with "Do Not load Main Volume/Balance" enabled.
I will likely revert back to loading main volume/balance for other reasons (mainly to have a recallable level for Speaker-B since there isn't a way to have the ARC control Speaker B w/o linking it to the Main - see my other feature request thread for that ) - but people might want to be aware about this potentially damaging issue.
You can likely overwrite all 8 snapshots with valid snapshots from your current configuration to alleviate the possibility of recalling an un-programmed snapshot with different Main Out routing.
As you were
2x SSL Alphalink MADI AX
