Topic: TMFX Dynamics Request: Higher Threshold & Shorter Release?
Any chance of increasing the dynamics threshold (specifically for the Expander/Gate)? I'm attempting to hard-gate some drum mics that feed a PA Mix and very loud full-range Drum Monitor to prevent resonant feedback and bleed (EQ+D is disabled to ASIO), and even with the highest threshold setting available, I still get lots of chatter and false opens (but loving the crazy low-latency TMFX affords me!).
Also, I believe the common release control can only sneak down to 100ms - any chance of lowering that to a shorter release time for faster Limiting and such?
And lastly (and unlikely) - will there ever be plans to add discrete Attack/Release controls for Comp and Expander separately? I'm mainly leaning on the Gates for now - so it's not a huge deal to use tight/quick Gate settings because I'm not compressing much (if any).
I could see a benefit to having them separated - especially when wanting the gate/expander at a VERY quick attack and the Dynamics at a higher attack so the dynamics can still breathe a little. Snare for example - you generally don't want the gate to open and also start compressing at the exact same time, and having discrete threshold controls alone will not allow you to accomplish this. It can be difficult to use the dynamics section for creative envelope control with the expander and compressor time-constants linked together.
Thanks for reading!
2x SSL Alphalink MADI AX
