Topic: Ideas for Analog Out 9652 Cubase 7.5 issues and Firestudio 2626
I really struggle with my DAW which has grown/evolved over the years. A year ago I swapped my 3 Delta 1010's for a RME HDSP 9652 running Cubase. Windows 7 64 system. Using Allen & Heath Mixwizard patched into a pair of Digimax LTs and Drums directly into a Digimax D8. All those into the 9652 via optical connectors. Everything is synched to HDSP 9652 internal clock and distributed via a Lucid GENx6 to all units. I was also using a Presonus Firestudio 2626 for monitoring. FS2626 is connected via firewire to PC with signal coming from 9652 and analog outputs from FS2626 into active monitors. I had a nice stable system. Then I upgraded to Cubase 7.5. I was not getting stereo output, although iTunes played back fine in stereo. So I went through PC settings, Cubase settings, RME mixer settings, and Firestudio settings. I managed to get it to work, but every time I re-boot the computer I have the same problem and have to re-do settings. Frustrating.
I believe the problem is having to select a generic setting versus the HDSP settings for playback. So.... I am now considering scrapping the Firestudio2626 so I can do everything directly through the HDSP 9652.
My long winded questions is... would the cheapest, easiest and most reliable solution be to just buy an RME AO4S-192 expansion card? It won't take up a PC slot and will give me 4 outputs and lock with the 9652 and RME mixer software. I can plug these directly into my active monitors. I can pick one up for between $200 and $300. Does anyone else have such a setup? Or is anyone using a Firestudio2626 with suggested settings that are stable (versus spending another couple hundred bucks)?
Thanks. Looking forward to getting back to tracking music. Thanks in advance for your responses. Happy New Year!
p.s. I kept at this and am able to get Cubase 7.5 to play stereo output but must change the VST Audio AISO devices every time. The generic AISO driver doesn't play in stereo. The 9652 doesn't play in stereo but shows all the inputs mapped correctly and captures properly, when I switch to the Presonus AISO I get stereo output but lose all my 9652 inputs. I suppose toggling between the two is a work around, but would prefer to have everything on same AISO.
