Topic: Disable control room
Hi Guys
Is it possible to disable the control room in totalmix? or at least to set the main-output to "none"
Controlroom is blocking Madi out 1+2, which i would like to use for virtual soundcheck..
/Kenneth
RME User Forum → TotalMix FX → Disable control room
Hi Guys
/Kenneth
Not sure what you mean by "blocking", these channels can still be used as usual even when assigned as Main in Control Room. Can you explain the problem in more detail?
I've copy/pasted my thread from gearslutz:
After changing my interface from the old RME PCI madiface to the new USB Madiface, i am now experiencing a odd thing, when doing Virtual SC.
Ch 1 + 2 is some kind of mixdown, instead of what it should be ("BD in + out").
All other channels is okay.
If i solo track 1 in nuendo live, it sends out the BD-track as it is supposed to..Seems like ether nuendo live or RME Totalmix is sending out a mixdown on 1+2?
have any of you guys tried something similar?/Kenneth
What do you have feeding the Main's Submix? If you retain a 1:1 routing for the Main CR section (MADI Inputs 1/2 to Main 1/2) then it should behave just like any other 1:1 routing outside the CR.
The CR Main Out is a submix just like any other Hardware Output (bottom row), it is just located on the Right side of the mixer and has a few bells and whistles a "regular" output channel doesn't.
In Totalmix FX menu, select Options > Reset Mix > Straight Playback. This will remove the playback mix from the Main outs.
