Topic: HDSP Madi PCI Low Lantecy Roundtrip measurement.
After many hours of work(weeks) i finaly got my system stabil.
I did some roundtrip measurement with some of my RME interfaces and Nuendo 6.
Using PC Gigabyte ex58-ud5 I7-920 win7 64bit and a lot of trimming(BIOS and Services...).
HDSP PCI MADI card, ADI-646 (madi-adat), OctaMic.(AD-ADAT) and ADI-Pro.(ADAT-DA).
Samplingfrequency is 48kHz.
Roundtrip AD-ADI-HDSP-ADI-DA: 1,54ms (without ADI and HDSP around 1ms using RAYDAT Card i think?).
With Nuendo64bit as ASIO/host, latency set to 32 (No cackle or dropouts occurs):
Roundtrip AD-ADI-HDSP-Nuendo-HDSP-ADI-DA:3,54ms
Nuendo has only total 2ms in/out delay and it is even with strip containing ie. lowcut-eq-comp without giving any extra delay but without limiter which give and exstra 1ms.
Insert Waves on channel:
Adding Waves Heq:4,90ms
Adding Waves API550:4,90
Adding Waves GEQ-Classic:4,96ms
Adding Waves C6-Sidechain:6,40ms at 48kHz (6,85ms at 44,1kHz)
All values are Total and my cpu is running pretty low.
DPC Around 110?s.
Measurent equipment: Ipad2 Interface: http://www.studiosixdigital.com/iaudiointerface2/
I can even use serveral Lexicon32bit Reverbs without any trouble.
I would like to try the same system on a MAC and even a PCIe HDSP Madi to see if any difference?
