Topic: Data lost and corrupted recordings
Hello
I have 2 rme raydat cards installed on each server.
The main task of the cards is to get the audio signal to the server. basically i use all adat in each brings 4 stereo channels.
I set one of the cards to perform as clock, here are images how is it setup:
http://f5.s.qip.ru/nzgdnGBF.png
http://f6.s.qip.ru/nzgdnGBG.png
the sound is forwarded to directsound and from there i record it.
The problem i face is that audio files have errors, such as:
missing few sec of audio
audio over audio [ small samples are heard, and after few seconds, i hear it again]
backround noise.
here is a short record with example:
http://www.sendspace.com/file/mnrwbj
Is there any problem with the way i configured the clock?
can it cause this issues?
is there a possibility that the buffer causing it?
Please advice where to look and fix the problem, as i do want to get more raydats.
Thank You
