Topic: Multiface 1 on HDSP 9632 via ADAT - possible?
Hi there,
I have here one HDSP 9632 with input expansion board in a standalone computer, and one Multiface 1 that I use with a laptop via Cardbus. All is working fine.
Now I would like to connect the Multiface 1 to the HDSP via ADAT in order to have more input channels. I am using two ADAT cables (signal and loopback). These are the tested setups so far:
1. The Multiface 1 is connected to the HDSP 9632 but also still to the laptop. The green lamp for the ADAT sync is lit. In the setup menu I see the ADAT sync (HDSP 9632 is the master, the Multiface the slave). However I can only see the Multiface input signals on the laptop, not on the standalone computer. With other words, the ADAT connection is synced but I don't see any delivered data.
2. Now I disconnect the Multiface 1 from the laptop for a test. The error LED blinks, after a restart of the Multiface it is constantly lit. No lock, no sync, no signal.
Ideally I had thought I could connect the Multiface as standalone expansion (without laptop) as ADAT slave to the HDSP 9632. Is that possible, and if so, how?
Thank you, Hannes
