Topic: Eq for bass management
For Bass management purposes, I would like to be able to add eq (low pass at 80Hz) on the following outputs of the software LRCLsRs and add an lowpass on the lfe output of the software at 120 Hz. One solution would be to have an EQ on the Send FX (which will be then sent to the sub) without activating the Reverb and the Echo.
Is it possible?
Simon
