I've requested this before, but is there really no way to have the ARC's "Speaker B" select option ALSO swap the encoder to control the Speaker B volume?
Linking Main & Speaker-B faders is problematic in my setup, and I don't believe my MF-XT even has a "Speaker B Level" option either. It would make the ARC that much more elegant in my setup.
However, making this use up another button on the limited ARC is also not desirable (and it would likely take a total of 3 buttons: One to select Speaker-B Output, one to select Speaker-B Encoder, and then one to re-select the Main Out Encoder when swapping back to Main Speakers).
Solution? Basically, the ability to add simple Macro commands to the ARC's buttons and the addition of a few simple commands (like the "Speaker B Level" command) to the configuration menu would allow this to happen via a single ARC Button.
But forcing the Encoder to automatically control Speaker B's volume when Speaker-B is selected would likely be preferred (and makes perfect logical sense IMO). People that want to keep them linked can, and both levels would match. Those that prefer discrete level control will have it...
Thanks for any consideration from a loyal RME fan
2x SSL Alphalink MADI AX
