Topic: 7.1 Surround Monitor Control
New to RME interfaces - I am shortly to take delivery of a FireFace802 and ARC.
I run 5.1 monitoring out of ProTools, through a BlueSky BM1 monitor controller. I wish to take it out of the signal chain, as it is pretty noisy (adding a fair amount of hiss and hum to the signal chain).
On my current setup (Motu Ultralite Hybrid + CueMixFX) you can control the level of the 8 main outputs in a variety of configurations (stereo, quad, 5.1, 7.1), from one "pot" on CueMix.
Reading through the manual for TotalMix, I noticed with interest the new "Monitor section".
Using the ARC, is it possible to control the level of the main 8 analogue outputs, and program calibrated settings, for TV, DVD or Cinema mixing?
Many thanks for any suggestions. The reason I am asking before I even take delivery is that I need to make the changeover as seamless and quick as possible!
Ta again.
Al.
ProTools 11.2.2HD on Windows & Mac, FireFace802 & ARC, Artist Control, Genelec Monitoring.
Re: 7.1 Surround Monitor Control
Currently there is no direct support for Surround in the Control room section. But you can link different outputs with the main output, thus having all surround channels controlled at the same time. By selecting different Snapshots, where you stored different output levels and/or mixing before, you can easily change between modified settings.
Just taken delivery, and very impressed so far.
However I cannot work out how to link an3/4, an5/6 and an7/8's levels to the main (an1/2) outputs level.
Any advice?
Alan
The manual explains how to build temporary and permanent fader groups.
And it's one of thickest manuals I've come across recently!
Have managed to figure it out, and now have all my analogue outputs linked and controlled from the ARC, and have snapshot calibrated levels set up. Even DIM works - brilliant!
For some reason though, I can get fader groups to work properly, but not mute groups.
Really though, RME should wake up and realise that a lot of people use their multi-channel interfaces for surround work, and get that monitor section actually useful. Digicheck does surround metering and R128 measurement, so this is all that's needed to make this THE go to interface for those of us working in sound for picture.
I've been using DAWs for 25 years now, and bar the Neves I've owned, this is the nicest sounding.
Mute groups are controlled with the mute group master button.
Georg
If I understood correctly, there is no factory built support for surround monitoring? But I could work around this by grouping output level faders?
Are the output level faders analog or digital? By analog I mean digitally remote controlled analog circuitry like the gains for mic inputs in Fireface for example. If they are digital, then it would be basically the same if I'd route software returns directly to hardware outputs at unity level and control my levels from DAW?
Are there any plans to add surround monitoring? It sure would be great. With the ability to downmix 5.1 into Lt/Rt stereo sum to main L and R speakers and then again downmix the Lt/Rt into mono sum to center speaker. Ability to assign a separate output for mono sum would be awesome even in normal stereo production. And the ability to phase invert Main L or R channel before summing to mono directly from Advanced Remote Control. I can currently achieve these functions in DAW with basic downmixing and tool/utility plugins placed in the master bus, but I have a tendency of forgetting them on when bouncing. It's not a big deal, but it is quite annoying to realize I have bounced offline a 2 hour long mono side sum version of the project. smile
8
Surround support will come within the Control Room Section, but we do not have plans to add downmix functions like you described.
Bloody Rippa!!!   (That's ..err... Fantastic! Awesome!). Can't wait for dedicated Control room support of surround MC! Not that I'm complaining about the implementation now, as it works really well using fader groups.... But it might mean that I can use "Do not load Main volume/balance" once again! great!
Matt McKenzie-Smith (UFXII, UFX, Babyface) MacStudioUltra OS13.2.1
10
That is one of the reasons that feature is needed smile
This is great news!
Is bass management part of the surround support in the control room section?
12
Of course you have the EQs and can set up manually whatever you need. Furhter plans are under discussion.
Hi there I am moving a monitor controller over from an SPL surround control. I am wanting an update when this might be available ? I am working around it so far linking all outputs to mute and fader groups. A button toggles mute group 1 etc. I have to work out how to individually mute each output when calibrating however.
soon 4 years gone by since a surround feature was "promised".  Any updates on this MC (RMEs Matthias Carstens)?
I am able to use the controller to manage fader and mute groups. This seems to suit my needs for now. I have a seperate fader / mute group for the phones out which goes to a custom headphone amp. So when I mute the main speakers I still have phones.
5 years later on surround support are still not available. Are there even gonna be surround support for totalmix? If not please let us know so i can decide whether I need to buy surround monitor controller or not. Currently I'm using arc remote..it works to some extent. But because of mute group limitation (4) basically you only can have 4 combination of solos (by muting other hardware output).
Any future (hopefully soon) plans for surround support?
Yes please to Surround Monitor Control. I have been waiting for this a while now. It seems such an obvious thing, especially in combination with the ARC. I would love to loose my SPL from the signal Path.
I have hope!
2019-01-30 MC wrote:
Topic: TotalMix FX 1.6 Beta 2 for Windows and Mac available
TotalMix FX 1.6 Beta 2 is now available. This time it's not about big feature updates, but a lot of fine-tuning and working on user feedback and wishes. And before someone asks: Better support for surround in the CRM section is planned for the next version, 1.7.
https://forum.rme-audio.de/viewtopic.php?id=28270
JohanW wrote:
I have hope!
RME is falling behind Metric Halo here. Their '3d' DSP has a complete b-chain for up to 7.1.4 surround built in. The issue is their interfaces don't have enough analogue outputs to make use of it which either requires multiple interfaces at great expense, mixing output types causing gain matching issues or going entirely to AES output rather negating the point of buying expensive Metric Halo DAC in the first place.
When RME originally showed no interest in surround this was justified because Ambisonics hadn't been picked up by Facebook for 'VR' sound and Dolby were still demanding a certified room for any Atmos work at all rather than just for the final render. Thus all the Dolby rooms had ProTools and AVID kit which is really a rebadged Digital Audio Denmark box.
As far as I'm aware there are two 7.1.4 or better dedicated monitor controllers on the market and they are both flawed.
The first is the JBL Intonato 24 which has speaker destroying noise problems on the analogue outputs in certain circumstances. the second is the Yamaha MMP1 which has signal to noise ratio problems on the analogue outputs. Which is odd because the matrix processors on which it is based are fine.
Thus if RME produced a interface with 16 analogue outs and the same kind of b-chain as Metric Halo are implementing then there would be a market for it.
YES!!!!
Bit slow coming in on this thread but have just mixed the first 25 minutes of a 5:1 documentary I wanted to add one thing.
The muting of TM playback channels works great across 6 or however many channels your surround mix has running BUT solo does not work because solo only works on all channels going to one stereo output pair.
I have TM setup for 5:1 as 6 mono playback channels feeding 6 mono output channels so solo does not work in this configuration.
I can't think of a workaround for that as I don't think there is one unless someone else has a good idea:-)
The only way to solo one channel is to mute the other 5 channels.
__________________________
Paul Najar
Jaminajar Music Production
www.jaminajar.com
MC,
I'm in the process of configuring a quadraphonic "workspace" in totalmix fx. I've tried linking a second pair of outputs to the main thru assign speaker b, to permanently gang with the main volume knob on the front of my UFX+, tho I'm seemingly am no longer able to pipe audio to them.
Secondly, I wonder if there are any updates in this realm that have been added since the printed manual was made.
Cheers,
Aaron
Speaker B is for a alternate set of monitors, not a group. Unassign that, and instead just link the faders using Fader Groups.
Oh ok, I see. Thank you.
Is there finally Surround support within the Control Room Section?
I am keen on upgrading from a Fireface 800 to an UFX and need at least 5.1 support.
We've all been doing it for ages.  It's all about fader groups.
Though I would leave this comment/ request here since this topic talks to the surround features in the control room section of totalmix.
Since we now know the room EQ and delay features will soon be added to TM, the one thing the control room assigned outputs require is dual mono functionality. Currently when you assign outputs to the control room section you can’t assign them as dual mono, only stereo. This limitation restricts the effectiveness of the soon to come room EQ and delay. Just thought I would flag that.
Kind regards
Paul Najar
www.jaminajar.com
28
You are aware that you can set individual Room EQ and delay for the stereo pair's channels?
29 (edited by paulnajar 2023-11-12 23:20:16)
Ah yes! Quite right. The functionality is similar to how the ADI-2 EQ works for Dual mono. This then leaves the matter of individual speaker level calibration and also single speaker mute functionality.
Mutes could be handled on the playback outputs as could speaker level calibration but if like me you're working with a control surface this would then mean system volume control and mutes operate on 2 different levels of the Control Surface. Not ideal.
it's not that big an issue. Totalmix is perfectly capable now for this you simply avoid using the  the control room section completely when monitoring 7.1.4 and use mono outputs but if you were to go to the bother of making TM aware of 12 or 16 channel monitoring in the Control Room there are still use cases where dual mono would matter for example if you wanted mute control over a single speaker rather than just be forced to work in pairs only.
Kind regards
Paul Najar
www.jaminajar.com
Kind regards
Hey Paul, as discussed elsewhere (I think) I mentioned how I was using GingerAudio Sphere, in conjunction with Totalmix.  This will change slightly for me, **if and when we get the new speaker calibration. I'll try an explain how I cover those things you mention above.
The following is all "at the moment" but may change**
This is mixing in Dolby ATMOS with Pro ToolsUlt.
1. ProTools driver --> Dolby Audio Bridge --> Dolby Atmos Renderer*** --> this is where the fun starts. (first 12 channels 7.1.4 go to Input D of SPHERE,   the next 6 go to Input E 5.1 re-render, Input F Stereo LoRo foldown re-render and then the next 2 binaural re-render).
2. The Main output of SPHERE (with SoundID Multichannel) goes to Totalmix. Now I have Totalmix sit at my room calibration level (-14dB on the fader linked main), then I have the SPHERE Alt (with a stereo SoundID) set to go to AES Totalmix which got directly to my Barefoot MM27s for stereo work.
Inidividual Speaker Mutes are handled on the Eucon monitoring page (driving SPHERE) of AVID Control.
My Logic setup is completely different and uses a similar setup for 7.1.4, but has a bypass using SourceNexus to bypass all of that for Low Latency recording.
Like I said elsewhere, I will try and make a video (not my field of expertise), where it would be much easier to explain.
Happy to have a chat Paul, on the phone or FaceTime, especially given we're in similar timezones, :-)
Hi Matt and thanks for the informative post.
I have all the answers and workflows I need in place now except for how to get limiting in Logic's master bus after the Atmos plugin to get printed into an ADMBWF but the other thing you talk about that's interesting to me is the idea of multiple render streams for export - say for example a 7.1.4 and a 5.1. Is this so you can bounce/ export both in the same pass? If it is, how do you deal with the different loudness reference levels for  EG Atmos (-18LUFS) and 5.1 (-24LUFS)Does the Dolby renderer figure this out for you? With all those alt mixes going to Sphere how to they get recorded back to disk? Back to Pro Tools inputs?
I've been doing multiple passes for this task adjusting loudness as desired. As an aside I've been doing more Atmos music mixing but a few films also. It's the music mixing I'm more interested in for now.
I have a far more simple setup than you it seems. After my DAW (Logic) all I have is Totalmix. You seem to have at least 2 further layers after DAW - Sphere and Dolby renderer. Sounds like you're happy with SoundID. I didn't get on with it too much - not enough customisation and I didn't always agree with it's choices and opted to use REW and measurement mic and did my own room eq moves.
My signal flow is after Logic's Atmos plugin I have a sample delay Plugin followed by 2 Linear Phase EQ plugins. This is where the speaker tuning and timing occurs. Once it leaves Logic it simply goes to Totalmix and Kali In-5's for all but L&R speakers which are currently Event Opals.
Still struggling to decide if I need Dolby Renderer software or not yet. When I first demoed it last year it was a lot less mature than the current version. What do you think of it? Is it essential for you?
What do you do for bass management? Sphere? For Atmos music mixing this is a big grey area. Many mixes don't put anything in the LFE or Centre speakers but then the playback system needs some kind of management to take advantage of the sub in a system.
The main excitement for me about RME's announced room eq/ delays is that it's a much better place to have this managed in Totalmix rather than on Logic's Master Channel. This will mean that for something simple like to listen to Apple Music currently I have to route it through Logic using Rogue Amoeba Loopback to get the speaker EQ's and delays. TM will handle this directly soon and all audio software will just go straight to Totalmix and no virtual IO software will be required ... Will definitely have a chat with you soon... Just have to wait for you to wake up in Adelaide:-)
Paul Najar
www.jaminajar.com
Hi Paul,
I'll sit down and answer those questions tonight after dinner.  Some are pretty straight forward, where others need parallel explanation if that makes sense.
Cheers,
Matt
33 (edited by hselters 2023-11-15 15:39:33)
Hey, following here– interesting thread.
@paulnajar, to add on Apple Music Atmos Playback which you touched upon: To make this work on macOS Ventura, it still requires a (virtual) audio interface with max. 16 channels.
I am currently using the "Pro Tools Audio Bridge 16" as an Output for macOS and my DAWs.
Then I am running Max as a plugin host which has  "Pro Tools Audio Bridge 16" as Input and "Fireface UFX+" as Output.
Max receives all playback channels (anything between Mono to 7.1.4), acts as a plugin host for Sonarworks Sound ID to calibrate speakers and headphones.
To come back to this thread's topic a bit: The Max patch also has simple Solo switches for each speaker, as this is something which still cannot be done in Total Mix. It would be great to have a Solo option on the Hardware Outputs in Total Mix, instead of the the CUE which I never use.
I also added 12 software thru's which go to my unused MADI Channels in Total Mix as those loopback into RME's Digicheck NG.
Unfortunately Digicheck only really supports 5.1 for the LUFS reading.
A downside is when working with video, there's no automatic delay compensation since things happen outside of the DAW.
@mattrixx: is this something Ground Control Sphere is taking care of? I saw it has EUCON integration which is nice, but can it report latency back to Pro Tools and other DAWs?
Also: Did anyone upgrade to Sonoma and can confirm that Atmos playback through Apple Music works directly with the RME driver?
Hey there hselters,
Yeah, SPHERE, does do delay compensation at the system level (even with multichannel SoundID). So when watching the TV app for example, everything is in sync.  When using ProTools with the DolbyRenderer and an external video device (such as Decklink etc) you still need to set your "Video Sync Offset..."
I check this regularly, to make sure software updates haven't changed anything. (you can use https://quietart.co.nz/catchinsync/ Catchinsync... or others).
SPHERE also has the Speaker Selects that the Dadman software has. (activated either on Eucon / Streamdeck / SPHERE itself).
When you say "Unfortunately Digicheck only really supports 5.1 for the LUFS reading", that is actually how it is measured in the Dolby renderer. ie From the manual - "Dolby Atmos: Provides loudness measurement for a Dolby Atmos master. This measurement is based on your selected 5.1 monitoring mode and applied trims."
(It makes sense when you consider that a Dolby Atmos Master file is not really a 7.1.4 interleaved file (with the exception of the compressed MP4 preview file). Think of it like a multitrack with up to 128 discrete audio channels...  with channels 11-128 controlled by embedded metadata for their respective location and size/dispersion etc etc. (very simplistic description).
Yeah, I am running Sonoma.
Sorry Paul, things got hectic last night, so didn't get a chance to reply.
1.  Master buss compression..  Mmm, we have to think differently about mixing in this regard. There are ways of doing it (using phantom busses S/C'd etc etc at a channel level, but you definitely do not want to be comp/limiting after the renderer, as this will only be working on the bed of an Atmos master (ADM/BWF). Just a collapsed mess.
2. Yes the Renderer measures loudness (You can measure in real-time, or you can load an ADM/BWF and do an offline measurement.) Regardless of whether you are running live re-renders, the loudness measurement is derived from a "Loudness re-render" enabled in preferences.  It is a 5.1 re-render including fold-down trim settings.
3. Post processing other fold-downs can be done after.  ie the Binaural fold-down is obviously going to be louder than the 7.1 / 5.1 etc.
4. SoundID does annoy me at times, but you can actually export your profile and load it into the Dolby renderer manually from the txt file.. (painfully slow, but effective) In SPHERE, you can just load SoundID on the chosen output.
5. SPHERE has Bass management, but mostly, I run full range in all but the .1 (Bass management is switchable).
It's all super exciting and makes you think/consider a lot more about everything. I was guilty of feeding a master buss with EQ/buss comp/Limiter.. forever. This just doesn't work in the same way with Atmos.
Cheers,
Matt
36 (edited by paulnajar 2023-11-16 06:48:00)
So a few things I can help here with. I started doing 7.1.4 over a year ago now on OS Monterey. As you rightly point out, to get Apple Music to play nice and stream Atmos required a 16 channel driver -either virtual or real hardware before it would output 7.1.4 audio channels. The same is true for Ventura. Last week I updated to Sonoma and only did a very brief test but yes - outputting Apple Music straight to my Madiface USB the Atmos channels work as they should. You still need to assign which outputs in AudioMidi setup.
All that said it's still useless unless your Atmos speakers are all exactly the same distance from listening position and don't require any eq. So for me that still means streaming Apple Music > Rogue Amoeba Loopback 16 channels > feed into Logic Pro where delays and EQ's are applied and you can also down mix in real time via the Logic Atmos plugin. After Logic it's off to Totalmix and speakers.
Also Digicheck NG Surround is enough to measure LUFS for Atmos as Atmos only takes in 5.1 channel for LUFS measurement.
When TM room EQ & delays come I will buy the UFX III. For now my Madiface feeds an ADI-648 which feeds 3 x Cranborne Audio 500Adat's and a UFX 1 and runs 99% of the time at 96Khz. The UFX 1 also feeds an ADI-2 Pro FS r be which feed my main front L&R. It will all get a lot more simple with the UFX3 and I won't need the Madiface or the UFX 1 anymore.
Paul Najar
www.jaminajar.com
Cheers,
Matt
Matt thanks so much for all the explanations!
The only thing I wonder is why would you want your SoundID profile loaded into the renderer and printed to your final output files? Isn't SoundID eq only designed to hear in your specific environment but not intended to be across final output?
Also my head scratching about how to include a limiter on my Adm BWF file output is really only to do safety peak limiting and it's really not changing the sound at all and I also find it useful for changing the overall output level to get the LUFS to conform for different downmixes.
I suppose I could simply use the master fader to do the same thing and problem solved.
Also guys, tip for music mixing in Atmos. The Centre and LFE channels are not on for about 50 - 65% of mixes I'm listening to on Apple Music. By leaving them off it allows a higher overall level without exceeding the -18 LUFS limit since both those channels are included in the 5.1 LUFS measurement for Atmos...
Kind regards
Paul Najar
Paul Najar
www.jaminajar.com
Kind regards
Paul Najar
Yes, fair question, but that EQ is not part of the ADMBWF file output. It's just for monitoring. It's part of the "Setup" menu then "Room Calibration".
The way ProTools and the DOLBY Renderer interact, is extremely clever and not just a straight into and out of affair.
I got a flow chart I've knocked up in Freeform (but you need Sonoma to see it....)
The DOLBY Renderer has an optional Soft Clip Limiter built in. (for speaker monitoring, headphone monitoring and re-renders).
But it is always best to get those peaks at the source. If happy with your mix and re-renders, you can always conform the re-renders after, using an offline process.
As far as compressing the master buss... you'd just have to be careful. ie if you had some vocals as objects and some running straight to the bed, only those going to the bed are going to be effected.
Nice call on the Centre LFE tip Paul.  It sure does make a difference in music.  I can't really do that in TV/Film for obvious reasons.
Someone once told me that the initial reason they were doing that, was that the record companies didn't want people picking off accapellas of the isolated main vocal in the centre. (not sure whether that was true or just heresy).
The whole Atmos exercise has been an extremely enlightening foray into mixing, feels like learning all over again and leaving some of the old ways of doing things (such as buss compression, spatial awareness etc etc).
Cheers
Matt
OK that makes sense. The renderer seems vast in functionality. I may need to give it another look.
I’m not attached to master bus compression too much. As said it really is a quick way to know I’m going to conform to nothing over the -1dBFS limit but to be honest I barely have to.
About the most I’ve used it was on a film I did earlier in the year where the client really wanted a LOUD 5.1 version to compete in the film festival presentation setting where the operator doesn’t adjust playback vole from movie to movie. By driving the input to the limiter I was able to get him a -11LUFS version which is totally non compliant but he loved it and if you poke around the net there are other in this situation of having to deliver in certain settings breaking the rules to stand out…
PN
Paul Najar
www.jaminajar.com
PN
Haha, had a similar experience recently regarding the loudness thing. Even many of the cinemas are all over the place with levels.
41 (edited by hselters 2023-11-16 13:13:07)
Oh yes, I agree. I recently mixed a commercial for cinema in 5.1, complying to 82 Leq(m). It wasn't really clear from the distributor if the limit of 82 Leq(m) is set for the momentary or overall measurement. I did two exports and they had a difference of -27 to -19 LUFS.
In the end went with the louder one which translated well, but would probably be smashing ears, if it got played back at the same level as a following movie, as those usually get mixed to the 85dB reference level.
I suspect playback volume of commercials must have a different playback level than the movie screening, but overall the levels of commercials did vary a a lot, with some being quite low. I was glad I did my homework and called the company who compiled the DCP for their advice.
Yes, that last bit is great advice. Mostly, I've found that when my 82LEQm masters kinda match my OP59 (Australia) -24LKfs masters, we're all pretty sweet.
But I've recently had a couple of examples of people (usually video interns) packing DCP's where 5.1 stems ended up mono in the stereo world. WTF??
So, I'm now always getting the agency producer send me the master so I can do a bit of QC.
Why did it have to come to this. LOL
