Topic: Need some help - I think with routing?
So, some time ago, I was having a problem getting sound into Audacity. That was solved. but only temporarily. It no longer works, and I am wondering if this is not a totalmixfx issue.
http://www.jeffreyhayat.com/mfx.jpg
is the issue potentially that I am not seeing anything in the hw inputs?
In my sounds (Win7 ctrl panel), in both pb and recording, the RME Analog 1&2 is set to default device. Any ideas?
RME HDSPe AIO with Windows7 Ult 64 bit.
Thanks in advance.
Re: Need some help - I think with routing?
Your screenshot shows the self-noise of the analog input, so it is working. There is just no signal attached from outside going in.
Ok, thanks. So, any idea on how to get this working?
Using the correct connectors?
Connectors? This is all ITB.
The inputs are hardware inputs. If you need to record a software output you have to create a loopback that routs the output back to input in totalmix. Not sure how, cause the HDSP9652 I have doesnt have that, but search for loopback in the manual(or menu)
Got it - had to check loopback on the hardware output channel.
Thanks.
