Topic: Fireface 802 class compliant mode
Hello everyone
I have installed another PC machine AVlinux operating system. Mainly I've been using Windows 10, which is still in use. I would now like to test how 802 works with this Linux. If I put 802 in class compliant mode, are all inputs and outputs available? For example, can I use an ipad to control totalmixfx at the same time. If not, how can I set headphone mixes to other outputs, for example. Apparently Directly from DAW.
Of course, direct Linuxt support would be desirable. But while waiting for it.
