Topic: Fireface 802 class compliant mode
Hello everyone
I have installed another PC machine AVlinux operating system. Mainly I've been using Windows 10, which is still in use. I would now like to test how 802 works with this Linux. If I put 802 in class compliant mode, are all inputs and outputs available? For example, can I use an ipad to control totalmixfx at the same time. If not, how can I set headphone mixes to other outputs, for example. Apparently Directly from DAW.
Of course, direct Linuxt support would be desirable. But while waiting for it.
Re: Fireface 802 class compliant mode
No. It's a hell.
https://linuxmusicians.com/viewtopic.php?t=25457
Didn't you already test it? You provided the descriptors for oscmix and it seemed you are already using the 802 with linux?
Can I use an ipad to control totalmixfx at the same time.
You can answer this Question by yourself. How should this work? Plugging one device to 2 Hosts, as it has one USB Port...?
I do not understand your other questions, aswell...
“Do It For Her”
4 (edited by sjzstudio 2024-05-13 13:46:17)
That's a 4 year old old question. I have since acquired a UFX+ device and am now using it. 802 is on the edge of the table waiting for better times. If they happen to come. Sometimes I thought of giving it to a driver developer, but shipping to the other side of the world is quite expensive.
The idea was to use it at home, but now I use a Behringer small usb device at home.
I'm also switching to Ubuntustudio. Because many things work easier in that environment and many audio plugins have started to use it as a reference system. So Ubuntu. Therefore, it might make sense to direct development resources to support Ubuntu. That seems like a good enough option. That is, if RME eventually ends up supporting Linux. Of course, I know there are a million other opinions on this.
I am sorry, sjzstudio. I should better look for the date!
“Do It For Her”
