Hi Thomas,
in this case you only need 3x OM3 or OM4 multimode cables with SC plug (which you get out of 2 duplex cables):
MADIface Pro ----- SC ----- M-32 Pro AD ----- SC ----- M-32 Pro DA ----- SC -----+
(MADIface Pro) ------------------------------------------------------------------------------+
BTW .. there are not only different connector standards (SC, LC) to consider. You should also decide on the type of multimode cable: OM3 (color: Aqua) or OM4 (color: Violet).
If the devices are in different floors / rooms and you need to use fiber optical inhouse cabling (OM3, OM4 multi-mode), then use the cable type of your inhouse cabling, don't mix OM3/4.
If you connect the devices back to back, then there is no difference between OM3 and OM4, both support 1km cable length with transfer speeds of 1 Gigabit. Only with transfer speeds of 10 Gbit and higher (which is both not the case here) then OM cabling gives you advantages in terms of max length. But as I said, for this type of cabling in a rack it does not matter, you should only stick to one cable standard and nowadays this is either OM3 or OM4.
In the past there was a price difference between OM3 and OM4 cables, but in the shop where I looked now, both cables had the same price, therefore I would suggest to simply choose OM4 cables (more flexible usable, "future proof").
BTW .. I would not look for simplex cables, some shops only offer duplex cables. I think then you will automatically get more hits .... You can make a single cable out of a duplex cable yourself easily. SC and LC cables have a plastic connector around the plugs which you can open and then you have quickly two separate cables (and in some cases one spare cable).
Back to back cabling (without in house cabling)? Get 2x OM4 Duplex cable of e.g. 1m (provide a little reserve regarding length):
OM4 SC-SC https://www.kabelscheune.de/LWL-Kabel-L … patchkabel
Two example for OM4 cables with other plugs that you might need in case of adding RME equipment using SC plugs:
OM4 LC-LC https://www.kabelscheune.de/LWL-Kabel-L … patchkabel
OM4 LS-LC https://www.kabelscheune.de/LWL-Kabel-L … patchkabel
BR Ramses
