Topic: RME HDSP 9652 - Error "hdspf init failed"
I get the error "hdspf init failed" during PC startup. I found some resources about this error on the internet but no clear solution for that.
It seems that the pc can not find the HDSP 9652 PCI Card and this means it is a hardware error. Is that the right interpretation of the error?
If this is correct, I need to do a hardware check. If not, it could also be a software driver problem which could be solved by go back to an older driver.
Best regards
Diggnity
Backtracks:
https://forum.rme-audio.de/viewtopic.php?id=31956 (hardware problem / broken usb cable)
https://forum.rme-audio.de/viewtopic.php?id=27409 (no solution noted)
