Topic: [Solved] UCX II Power Jack is Horrible (Same Problem as UC)
I just upgraded from UC to UCX II. Brand new unit, plugged it in and no power. Green light on cable is on. Then I remembered I had this issue with my UC after light use. I jiggled the power input cable downward and it worked. The input connector is broken / loose.
RME is such a high quality product. How can they not design a better power jack? Seems they pack so much into a small box with frail components. The power jack needs to be able to last over years of use. This happened to my UC after about one year of use after I bought it in 2011. This UCX II is brand new and didn't work the very first time. There is no way the input jack should break when I carefully plug in the power cord.
RME, you need to redesign your input jack. It needs to be solid. Now I need to go through the inconvenience of returning the product.
