1 (edited by zcyh_147 2022-08-10 08:27:20)
Topic: Reference level with Fireface UFX+ and ADI-8 QS
I looked through the manual for the UFX+ and found that when its output reference level is set to +4 dBu, the 0 dBFS is actually +13 dBu.
https://i.ibb.co/FgRqWPP/c5061d93-8007-49aa-8512-3a12c62f6f80.png
I would like to ask if I should select the level after that according to +4 dBu or +13 dBu in this case in subsequent device connections?
My usage scenario is quite strange, it is the output signal from the UFX+ that goes to the monitor controller, and then the Aux Out signal from the monitor controller summed up (monitor controller has some other signal input) goes to the ADI-8 QS, so I need to clarify whether the Input level of the ADI-8 QS is selected at +4.2 dbu or +13 dbu.
Thx:)
Re: Reference level with Fireface UFX+ and ADI-8 QS
If the input signal is
— too hot you need more headroom, then select Hi Gain, you will see that the input signal goes down
— too low, then you need more sensitivity on the inputs, then try either +4 (typical studio level) or -10 (consumer level)
BR Ramses
Thanks for your kind reply, ramses!
But my problem is the input signal selection of the ADI-8 QS sad, which only has the following input levels available:
https://i.ibb.co/QdxhdJ1/2022-08-12-2-09-05.png
In fact, the reason why I would ask such a question is because the output signal of the ADI-8 QS I will use to measure the signal Loudness, if I can not choose the exact input level, then the Loudness result is wrong sad
4 (edited by ramses 2022-08-12 13:34:48)
Hi zcyh_147
you can add digital gain up to +6 dB in 0.5dB steps on inputs and outputs, see manual ch 9.3 and 9.4 (input and output trim).
https://www.rme-audio.de/downloads/adi8qs_e.pdf
See also here
https://forum.rme-audio.de/viewtopic.ph … 96#p190096
As you can see from that thread you need +3 dB more digital gain to come from +4dB studio level to -10 dBV consumer level.
ADI-8 QS has a reflevel of +4.2dB , so you need tad a bit more than +3dB digital gain pr try the next higher setting and look what works best for you.
And welcome to the forum :-)
BR Ramses
Hi zcyh_147
See also here
Thanks ramses!
I seem to understand that, assuming that the ADI-8 QS receives a signal with an input level of +6dbu, then I can select the input level of the ADI-8 as +4.2dbu and add 2dbu + 3dbu (as Headroom) gain to it, I don't know if I understand correctly.
Because the reference level (e.g. +6dbu in the example above) only represents the level when the signal is clipping, and usually a little Headroom needs to be reserved for it.
And also thanks for you kind welcome smile
As a long-time RME user, this is my first time to speak in the forum.
