Topic: Reference level with Fireface UFX+ and ADI-8 QS
I looked through the manual for the UFX+ and found that when its output reference level is set to +4 dBu, the 0 dBFS is actually +13 dBu.
I would like to ask if I should select the level after that according to +4 dBu or +13 dBu in this case in subsequent device connections?
My usage scenario is quite strange, it is the output signal from the UFX+ that goes to the monitor controller, and then the Aux Out signal from the monitor controller summed up (monitor controller has some other signal input) goes to the ADI-8 QS, so I need to clarify whether the Input level of the ADI-8 QS is selected at +4.2 dbu or +13 dbu.
Thx:)
