1 (edited by mr-es335 2022-11-10 19:14:45)
Topic: HDSP 9632 and TotalMixFX
Good day,
May I ask why the TotalMixFX - Matrix View, displays OUT 1-2, then OUT 7 to 16?
Where are OUTS 1-6?
Thank you for your time!
Dell Krauchi
Sentinel Music Studios
2 (edited by ramses 2022-11-10 19:22:04)
Re: HDSP 9632 and TotalMixFX
What's your sample rate? Did you enable quad speed?
Check manual ch 18. There you see 4 ADAT channels @double speed.
At quad speed its 50% less, two channels because of port multiplexing.
SPDIF and analog ports are not affected.
BR Ramses
Ramses,
Thanks for the reply.
My sample rate is 48K
Dell Krauchi
Really? Don't be fooled, maybe you use a different sample rate when using DAW/ASIO driver compared to using WDM driver for Windows and other apps that do not support ASIO.
BR Ramses
5 (edited by vinark 2022-11-10 20:56:55)
At least you have the correct number of outputs,1 and 2 are analog, 7 and 8 spdif and 9/16 adat. I think maybe 3/6 are for the expansion board that was-is available. Are spdif and adat 1/8 available in TMFX?
Could also be 7-14 adat and 15 and 16 spdif
Order of ports is different in the manual, vinark. Could kindly cross-check ch 18?
https://www.rme-audio.de/downloads/hdsp9632_d.pdf
https://www.rme-audio.de/downloads/hdsp9632_e.pdf
BR Ramses
7 (edited by vinark 2022-11-10 21:32:19)
It is about the naming, you have 4 places with names,
1 in TMFX
2 in the matrix
3 in asio
4 in wdm
As far as I can see numbering/sequence is only different in the matrix.
I will see if I can check here, I have not fired my machine with the hdsp9632 in a while.
Oh I forgot, my hdsp9632s are in my caravan.
ramses and vinark,
Thanks for the replies...appreciated.
The user manual is pretty much useless to me - especially the diagrams. Totally lost!
I only use a single DAW application - all other audio sources are disabled running on WIN7 Pro.
• This system is dedicated to one function - and one function only.
If the primary functionality of the Matrix View is for more complex routings, then I really do not see any need for me to ever use the Matrix View.
At present my system uses ADAT 1/2 IN and ADAT 1/2 OUT...that is it!
Dell Krauchi
It's fine to use submix mode.
I started to use the matrix after deleting all routings and implementing only the required ones.
BR Ramses
10
The additional channels are for the AI/AO extensions, but stay invisible when no such extension is plugged in. When you see these channels in the matrix but not the mixer view this might be a simple graphics bug in TM FX. Which version are you using? Latest one is 1.78, in just released driver 4.39.
