1 (edited by tom.crandles 2023-06-08 15:49:50)
Topic: Help Required: Pro Tools UFX I/O Setup
Hi there,
I have a UFX II which all works exactly as i want it to with Ableton. Incredible piece of kit. However I've decided to take all my mixing over to Pro Tools and for some reason i just cant get Pro Tools to read the inputs from the UFX. I purchased Pro Tools 3 days ago and I'm running it on Windows.
After a little fiddling I've managed to send some audio out of the UFX to my hardware but inputs are a no go. When i go to select an input on a track the 'interface' option is greyed out.
After hours of troubleshooting i just can't seem to figure it out.
I should mention Pro Tools is somewhat new to me. Does anyone happen to have any advice on setting a UFX II up with Pro tools? Anyone who can help will be showered in gratitude.
All the best and thank you in advance for your response,
Tom
Re: Help Required: Pro Tools UFX I/O Setup
Was Ableton running ? May you have to deselect UFX in Ableton prior to be able to select it in PT ?
M1-Ventura, Madiface Pro, Digiface USB, Babyface silver and blue
All works totally fine in Ableton, In fact I'm using it now as we speak.
Oh i misread your post.
No i wasnt using ableton at the same time.
https://forum.rme-audio.de/viewtopic.php?id=27952
