jn4u.jn4u wrote:I have a Babyface Pro and Digiface USB and they are connected to same computer. I want to run the BabyFace Pro in Full Mode and the Digiface USB in Digital Workstation mode. But every time i change inside TotalMix FX it’s opertionmode it effects both units.
Works as designed. DAW mode was introduced for people who wanted to route in the DAW and nothing else.
The intention was not to finally have different TM FX instances with different modes...
But I do not see any issues … Simply use TM FX full mode in both instances.
With a mouse click, you can get in TM "Full Mode" the same routing as in DAW mode.
See my posting here: https://forum.rme-audio.de/viewtopic.ph … 26#p190726
Moreover, you have the possibility to add additional routings through the digital matrix of the interface just in case you need to a lower RTL for certain monitoring flows.
