Topic: Total Mix Crash under macOS Sonoma
I just went from a Mackintosh to a M1 Ultra Mac Studio. My Interface is the Madiface XT. With the new Computer I get lots of freezes of Totalmix, which then leads to freezing of Youtube and Apple Music.  I am during the installation process, so, I have not tested Cubase, yet.
In the beginning this always happened a few minutes after every restart. After looking at the forum, I went for this driver ….
https://forum.rme-audio.de/viewtopic.php?id=38131
… and this Software version of Totalmix (just replaced it by dropping it in the Apps folder).
https://forum.rme-audio.de/viewtopic.php?id=37958
But even now, I still get freezes of Totalmix! It just does not happen as quickly any more. It my also be related to the Apple Music App or Safari or Youtube,
Anyone else who got similar freezes? Or any hints what I might try?
Re: Total Mix Crash under macOS Sonoma
You did not mention firmware, did you also update the MADIface XT firmware version?
https://rme-audio.de/downloads/fut_madiface_mac.zip
Yes, I already was on the latest Firmware. To be sure, I just downloaded your link and the firmware updater showed nothing newer to update on: PCIe 56, DSP 42 and USB 191.
This needs some more info and tests to maybe pin it down:
- when TM FX freezes does audio still work?
- did you check the Settings dialog for USB errors shown?
- does it help to close or completely exit TM FX?
- are any MIDI ports assigned within TM FX for in and out?
5 (edited by kol.ut.shan 2023-10-26 11:03:01)
I have the exact same issue, so I add to the topic:
Mac Studio M2
macOS Sonoma 14 (also 14.1)
HDSPe Madi FX - latest firmware
Latest DriverKit Driver 1.10
TM v. 1.85
- TM freezes only when the machine was unattended and this can happen over nigh, when the screensaver went on (so even just after 5m or so) or after waking up from sleep
- Audio does not work anymore (any kind of playback)
- Applications like Spotify or Youtube playback "get stuck"
- TM can't be opened anymore
- When TM is forced quit and restarted audio playback is possible again (a reboot also fixes the issue)
- In my case no MIDI is used in TM
6 (edited by trubadix 2023-10-26 22:25:44)
No, it does work no longer after freezing. Only restarting the OS makes it work again.
Yes, I never saw anything else than "CRC 0 Errors". Although I just saw that it shows "USB2", although it is connected with a USB 3 cable - the same one that perfectly worked on the Mackintosh before. I am not sure. Is that normal?
edit: Now it shows USB3 again after a restart. I am not sure why ...
No. I can force-quit TM, but the Audio only comes back after a restart of the OS.
No, I never used the midi of the Madi FX or routed anything to TM FX.
7
Can you exit TM FX after boot and setting your desired settings, to check if the error still shows up later?
Also: if you Force Quit TM FX in the hanging state you usually get a report wihich might include useful info for us.
Since yesterday, I did not have a freeze, so, I will have to wait and see when it will happen next and report back. Regarding the settings: I got multiple times a pop up window leaving me with the choice of recalling the settings from the device or uploading the default to the device. But I will also keep that and mind and report the next time it happens.
9 (edited by kol.ut.shan 2023-10-31 10:38:17)
I just had to force quit TM and saved the crash report as a txt file (for some reason I cant see it in Console app and therefore not export it) where can I send the log to?
Edit: I've just used the email function of the forum to send the log to MC
10
Received, thanks.
Ok, meanwhile I got some more crashes. This is the report after the last crash of total mix. It is always the same: during playback, the audio suddenly stops and all apps using audio crash together with Total Mix FX. I can only resart the PC. Otherwise, Total Mix will not start again.
panic(cpu 0 caller 0xfffffe002f0b5cbc): Kernel data abort. at pc 0xfffffe00313a8560, lr 0xfffffe003143ccbc (saved state: 0xfffffe8a05d6b7d0)
      x0:  0xfffffe1668b49200 x1:  0xfffffe24cae0bc90  x2:  0x00000000e00002eb  x3:  0x0000000000000000
      x4:  0x72f67e00313a853c x5:  0x0000000000000000  x6:  0xfffffe002de822c0  x7:  0xfffffe002de81d20
      x8:  0xfffffe1668b49208 x9:  0x00000000e0005000  x10: 0x0000000000800000  x11: 0x0000000000000000
      x12: 0x0000000000000000 x13: 0xfffffe0034bca830  x14: 0x0000000000000000  x15: 0x0000000000000001
      x16: 0x72f67e00313a853c x17: 0x000000000000e90c  x18: 0x0000000000000000  x19: 0xfffffe16689ddc00
      x20: 0xfffffe1fffee3940 x21: 0x0000000040000001  x22: 0x0000000000000000  x23: 0x0000000000000000
      x24: 0x43a4fe003046fa68 x25: 0x0000000000000000  x26: 0xfffffe16689ddc00  x27: 0xfffffe0031f1cc18
      x28: 0xfffffe2999a34ab8 fp:  0xfffffe8a05d6bd20  lr:  0xfffffe003143ccbc  sp:  0xfffffe8a05d6bb20
      pc:  0xfffffe00313a8560 cpsr: 0x80401208         esr: 0x96000047          far: 0xfffffe1668b4935c
Debugger message: panic
Memory ID: 0x6
OS release type: User
OS version: 23B81
Kernel version: Darwin Kernel Version 23.1.0: Mon Oct  9 21:27:24 PDT 2023; root:xnu-10002.41.9~6/RELEASE_ARM64_T6000
Fileset Kernelcache UUID: 9B88AE46569577FF0B82A48EAE38CDC6
Kernel UUID: 88BB97DD-3D4F-3EB9-8DDE-FFC364B55886
Boot session UUID: 8DCBAA06-FD2C-4F57-9FBD-11035FBA02D8
iBoot version: iBoot-10151.41.12
secure boot?: YES
roots installed: 0
Paniclog version: 14
KernelCache slide: 0x0000000026314000
KernelCache base:  0xfffffe002d318000
Kernel slide:      0x000000002631c000
Kernel text base:  0xfffffe002d320000
Kernel text exec slide: 0x000000002783c000
Kernel text exec base:  0xfffffe002e840000
mach_absolute_time: 0x1c52c10610
Epoch Time:        sec       usec
  Boot    : 0x655540d6 0x0009e483
  Sleep   : 0x00000000 0x00000000
  Wake    : 0x00000000 0x00000000
  Calendar: 0x6555549c 0x000d264a
Zone info:
  Zone map: 0xfffffe1000770000 - 0xfffffe3000770000
  . VM    : 0xfffffe1000770000 - 0xfffffe14cd43c000
  . RO    : 0xfffffe14cd43c000 - 0xfffffe1666dd4000
  . GEN0  : 0xfffffe1666dd4000 - 0xfffffe1b33aa0000
  . GEN1  : 0xfffffe1b33aa0000 - 0xfffffe200076c000
  . GEN2  : 0xfffffe200076c000 - 0xfffffe24cd438000
  . GEN3  : 0xfffffe24cd438000 - 0xfffffe299a104000
  . DATA  : 0xfffffe299a104000 - 0xfffffe3000770000
  Metadata: 0xfffffe302600c000 - 0xfffffe302e00c000
  Bitmaps : 0xfffffe302e00c000 - 0xfffffe303e00c000
  Extra   : 0 - 0
Probabilistic GZAlloc Report:
  Zone    : kalloc.type1.512
  Address : 0xfffffe1668b4935c
  Submap  : GEN0 [0xfffffe1666dd4000; 0xfffffe1b33aa0000)
  Kind    : use-after-free (medium confidence)
  Metadata: zid:267 inl:1 cl:0x0 0x0000 0x00000000 0x00000000 0x00016a2a
TPIDRx_ELy = {1: 0xfffffe24cd0e7010  0: 0x0000000000000000  0ro: 0x0000000000000000 }
CORE 0 PVH locks held: None
CORE 1 PVH locks held: None
CORE 2 PVH locks held: None
CORE 3 PVH locks held: None
CORE 4 PVH locks held: None
CORE 5 PVH locks held: None
CORE 6 PVH locks held: None
CORE 7 PVH locks held: None
CORE 8 PVH locks held: None
CORE 9 PVH locks held: None
CORE 10 PVH locks held: None
CORE 11 PVH locks held: None
CORE 12 PVH locks held: None
CORE 13 PVH locks held: None
CORE 14 PVH locks held: None
CORE 15 PVH locks held: None
CORE 16 PVH locks held: None
CORE 17 PVH locks held: None
CORE 18 PVH locks held: None
CORE 19 PVH locks held: None
CORE 0 is the one that panicked. Check the full backtrace for details.
CORE 1: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a053e3ef0
CORE 2: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a0582bef0
CORE 3: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a05b37ef0
CORE 4: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a03e47ef0
CORE 5: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a02fbfef0
CORE 6: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a06203ef0
CORE 7: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a05b1fef0
CORE 8: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a051bbef0
CORE 9: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a058afef0
CORE 10: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a05d2fef0
CORE 11: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a052abef0
CORE 12: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a05fefef0
CORE 13: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a05f0fef0
CORE 14: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a05cffef0
CORE 15: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a0601fef0
CORE 16: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a05a6bef0
CORE 17: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a064e7ef0
CORE 18: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a06233ef0
CORE 19: PC=0xfffffe002e8d4620, LR=0xfffffe002e8d4620, FP=0xfffffe8a05ca7ef0
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Panicked task 0xfffffe1666e9d908: 0 pages, 913 threads: pid 0: kernel_task
Panicked thread: 0xfffffe24cd0e7010, backtrace: 0xfffffe8a05d6af00, tid: 72517
          lr: 0xfffffe002e8995e0  fp: 0xfffffe8a05d6af90
          lr: 0xfffffe002e9e436c  fp: 0xfffffe8a05d6b000
          lr: 0xfffffe002e9e27e8  fp: 0xfffffe8a05d6b0f0
          lr: 0xfffffe002e847aa4  fp: 0xfffffe8a05d6b100
          lr: 0xfffffe002e898ebc  fp: 0xfffffe8a05d6b4b0
          lr: 0xfffffe002f0ab260  fp: 0xfffffe8a05d6b4d0
          lr: 0xfffffe002f0b5cbc  fp: 0xfffffe8a05d6b650
          lr: 0xfffffe002e9e41c8  fp: 0xfffffe8a05d6b6c0
          lr: 0xfffffe002e9e2a9c  fp: 0xfffffe8a05d6b7b0
          lr: 0xfffffe002e847aa4  fp: 0xfffffe8a05d6b7c0
          lr: 0xfffffe003143ccbc  fp: 0xfffffe8a05d6bd20
          lr: 0xfffffe003046fb54  fp: 0xfffffe8a05d6bd50
          lr: 0xfffffe002efad2b8  fp: 0xfffffe8a05d6bdc0
          lr: 0xfffffe003046f9d0  fp: 0xfffffe8a05d6bdf0
          lr: 0xfffffe002e8fa3fc  fp: 0xfffffe8a05d6be30
          lr: 0xfffffe002e8fb45c  fp: 0xfffffe8a05d6bf20
          lr: 0xfffffe002e850ed8  fp: 0x0000000000000000
      Kernel Extensions in backtrace:
         com.apple.driver.usb.AppleUSBCommon(1.0)[7360CCED-F410-3A3C-BF7C-3E5812B3BC99]@0xfffffe003046c150->0xfffffe003047100b
         com.apple.iokit.IOUSBHostFamily(1.2)[9D76404F-181D-3643-875F-D82739B01CC4]@0xfffffe00313a1a00->0xfffffe0031453347
            dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[B562E2F2-059F-3F75-9A50-57B08E283880]@0xfffffe002fdae820->0xfffffe002fdde8eb
            dependency: com.apple.driver.AppleSMC(3.1.9)[F86184CF-3AA6-3E13-83DA-E7B4B8977DD8]@0xfffffe002ffb8170->0xfffffe002ffdcb33
            dependency: com.apple.driver.usb.AppleUSBCommon(1.0)[7360CCED-F410-3A3C-BF7C-3E5812B3BC99]@0xfffffe003046c150->0xfffffe003047100b
            dependency: com.apple.driver.AppleUSBHostMergeProperties(1.2)[D4A08E8E-0BED-3B61-AF9D-6D540D16FE52]@0xfffffe0031503950->0xfffffe003150447b
last started kext at 119158141982: com.samsung.magicianpssd.driver    8.0.0 (addr 0xfffffe002d180000, size 1729)
last stopped kext at 107325746830: com.samsung.magicianpssd.driver    8.0.0 (addr 0xfffffe002d180000, size 1729)
loaded kexts:
com.uaudio.driver.UAD2System    10.2.5
com.apple.filesystems.smbfs    5.0
com.apple.driver.AppleALSColorSensor    1.0.0d1
com.apple.filesystems.autofs    3.0
com.apple.AppleEthernetAquantiaAqtionFirmware    1.0.36
com.apple.driver.AppleTopCaseHIDEventDriver    7400.26
com.apple.driver.AppleUSBTopCaseDriver    7400.26
com.apple.iokit.SCSITaskUserClient    492
com.apple.driver.usb.realtek8153patcher    5.0.0
com.apple.driver.AppleBiometricServices    1
com.apple.driver.CoreKDL    1
com.apple.driver.usb.AppleUSBHostBillboardDevice    1.0
com.apple.driver.AppleUSBMassStorageInterfaceNub    556
com.apple.driver.AppleAOPVoiceTrigger    300.7
com.apple.driver.BCMWLANFirmware4387.Hashstore    1
com.apple.driver.DiskImages.ReadWriteDiskImage    493.0.0
com.apple.driver.DiskImages.UDIFDiskImage    493.0.0
com.apple.driver.DiskImages.RAMBackingStore    493.0.0
com.apple.driver.DiskImages.FileBackingStore    493.0.0
com.apple.driver.AppleUSBDeviceNCM    5.0.0
com.apple.driver.AppleFileSystemDriver    3.0.1
com.apple.nke.l2tp    1.9
com.apple.filesystems.tmpfs    1
com.apple.filesystems.nfs    1
com.apple.filesystems.lifs    1
com.apple.filesystems.apfs    2235.41.1
com.apple.IOTextEncryptionFamily    1.0.0
com.apple.filesystems.hfs.kext    650.0.2
com.apple.security.BootPolicy    1
com.apple.BootCache    40
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib    1.0.0
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless    1.0.0d1
com.apple.driver.SEPHibernation    1
com.apple.driver.AppleSmartBatteryManager    161.0.0
com.apple.driver.AppleThunderboltIP    4.0.3
com.apple.driver.AppleSN012776Amp    700.46
com.apple.AppleEmbeddedSimpleSPINORFlasher    1
com.apple.driver.AppleSamsungSerial    1.0.0d1
com.apple.driver.AppleSPIMC    1
com.apple.driver.AppleS8000DWI    1.0.0d1
com.apple.driver.AppleCS42L84Audio    700.46
com.apple.driver.AppleMCDP29XXUpdateSupport    1
com.apple.driver.AudioDMAController-T600x    300.15
com.apple.driver.AppleS5L8960XNCO    1
com.apple.driver.AppleAVE2    703.40.1
com.apple.driver.AppleSmartIO2    1
com.apple.driver.AppleSerialShim    1
com.apple.AGXG13X    276.56
com.apple.driver.AppleMobileDispT600X-DCP    140.0
com.apple.driver.ApplePMP    1
com.apple.driver.AppleT6000SOCTuner    1
com.apple.driver.AppleT6002CLPC    1
com.apple.driver.ApplePMPFirmware    1
com.apple.driver.AppleT6001PMGR    1
com.apple.driver.AppleEventLogHandler    1
com.apple.driver.AppleInterruptControllerV2    1.0.0d1
com.apple.driver.AppleS8000AES    1
com.apple.driver.AppleProResHW    326.11.0
com.apple.driver.AppleAVD    735.1
com.apple.driver.AppleJPEGDriver    6.2.2
com.apple.driver.AppleS5L8920XPWM    1.0.0d1
com.apple.driver.usb.AppleSynopsysUSB40XHCI    1
com.apple.driver.AppleSDXC    3.4.3
com.apple.driver.AppleT8110DART    1
com.apple.driver.AppleBluetoothModule    1
com.apple.driver.AppleBCMWLANBusInterfacePCIe    1
com.apple.driver.AppleS5L8940XI2C    1.0.0d2
com.apple.driver.AppleT6000DART    1
com.apple.driver.AppleT6000    1
com.apple.driver.AppleM68Buttons    1.0.0d1
com.apple.iokit.IOUserEthernet    1.0.1
com.apple.driver.usb.AppleUSBUserHCI    1
com.apple.iokit.IOKitRegistryCompatibility    1
com.apple.iokit.EndpointSecurity    1
com.apple.driver.AppleDiskImages2    273
com.apple.AppleSystemPolicy    2.0.0
com.apple.nke.applicationfirewall    404
com.apple.kec.InvalidateHmac    1
com.apple.kec.AppleEncryptedArchive    1
com.apple.driver.driverkit.serial    6.0.0
com.apple.driver.AppleActuatorDriver    7400.42
com.apple.driver.AppleHSBluetoothDriver    7400.26
com.apple.driver.IOBluetoothHIDDriver    9.0.0
com.apple.driver.AppleMultitouchDriver    7400.42
com.apple.driver.AppleInputDeviceSupport    7410.1
com.apple.driver.AppleHIDKeyboard    7400.2
com.apple.driver.usb.cdc.ecm    5.0.0
com.apple.driver.usb.cdc.acm    5.0.0
com.apple.driver.usb.serial    6.0.0
com.apple.driver.usb.IOUSBHostHIDDevice    1.2
com.apple.driver.AppleMesaSEPDriver    100.99
com.apple.iokit.IOBiometricFamily    1
com.apple.driver.AppleEthernetAquantiaAqtion    1.0.64
com.apple.driver.usb.cdc    5.0.0
com.apple.driver.AppleUSBAudio    610.3
com.apple.iokit.IOAudioFamily    500.4
com.apple.vecLib.kext    1.2.0
com.apple.driver.AppleThunderboltPCIUpAdapter    4.1.1
com.apple.driver.AppleThunderboltUSBUpAdapter    1.0.4
com.apple.driver.AppleThunderboltDPOutAdapter    8.5.1
com.apple.driver.AppleAOPAudio    300.14
com.apple.driver.DiskImages.KernelBacked    493.0.0
com.apple.driver.AppleXsanScheme    3
com.apple.driver.usb.networking    5.0.0
com.apple.nke.ppp    1.9
com.apple.driver.AppleBSDKextStarter    3
com.apple.kext.triggers    1.0
com.apple.filesystems.hfs.encodings.kext    1
com.apple.driver.AppleSyntheticGameController    11.1.9
com.apple.driver.AppleBTM    1.0.1
com.apple.driver.IOHIDPowerSource    1
com.apple.driver.AppleCallbackPowerSource    1
com.apple.driver.AppleConvergedIPCOLYBTControl    1
com.apple.driver.AppleConvergedPCI    1
com.apple.driver.AppleBluetoothDebug    1
com.apple.driver.AppleSEPHDCPManager    1.0.1
com.apple.driver.AppleTrustedAccessory    1
com.apple.iokit.AppleSEPGenericTransfer    1
com.apple.driver.usb.AppleEmbeddedUSBXHCIPCI    1
com.apple.driver.usb.AppleUSBXHCIPCI    1.2
com.apple.driver.AppleUVDMDriver    1.0.0
com.apple.driver.AppleUVDM    1.0.0
com.apple.driver.AppleThunderboltPCIDownAdapter    4.1.1
com.apple.driver.AppleThunderboltUSBDownAdapter    1.0.4
com.apple.driver.AppleThunderboltDPInAdapter    8.5.1
com.apple.driver.AppleThunderboltDPAdapterFamily    8.5.1
com.apple.driver.AppleDCPDPTXProxy    1.0.0
com.apple.driver.DCPDPFamilyProxy    1
com.apple.AGXFirmwareKextG13XRTBuddy    276.56
com.apple.AGXFirmwareKextRTBuddy64    276.56
com.apple.driver.AppleHPM    3.4.4
com.apple.driver.AppleStockholmControl    1.0.0
com.apple.driver.AppleI2CEthernetAquantia    1.0.0
com.apple.driver.AppleDiagnosticDataAccessReadOnly    1.0.0
com.apple.driver.AppleCSEmbeddedAudio    700.46
com.apple.driver.AppleEmbeddedAudio    700.46
com.apple.iokit.AppleARMIISAudio    300.11
com.apple.driver.AppleSPMIPMU    1.0.1
com.apple.driver.AppleDialogPMU    1.0.1
com.apple.driver.AppleSPU    1
com.apple.driver.AppleMCA2-T600x    800.11
com.apple.driver.AppleEmbeddedAudioLibs    300.1
com.apple.driver.AppleSPMI    1.0.1
com.apple.driver.DCPAVFamilyProxy    1
com.apple.iokit.IOGPUFamily    93.10.1
com.apple.iokit.IOMobileGraphicsFamily-DCP    343.0.0
com.apple.driver.AppleDCP    1
com.apple.driver.AppleFirmwareKit    1
com.apple.driver.AppleFirmwareUpdateKext    1
com.apple.iokit.IOMobileGraphicsFamily    343.0.0
com.apple.driver.AppleM2ScalerCSCDriver    265.0.0
com.apple.driver.ApplePassthroughPPM    3.0
com.apple.driver.ApplePMGR    1
com.apple.iokit.IONVMeFamily    2.1.0
com.apple.driver.AppleNANDConfigAccess    1.0.0
com.apple.driver.AppleARMWatchdogTimer    1
com.apple.driver.AppleSART    1
com.apple.driver.AppleT6000TypeCPhy    1
com.apple.driver.AppleT8103TypeCPhy    1
com.apple.driver.AppleUSBXDCIARM    1.0
com.apple.driver.AppleUSBXDCI    1.0
com.apple.iokit.IOUSBDeviceFamily    2.0.0
com.apple.driver.usb.AppleSynopsysUSBXHCI    1
com.apple.driver.usb.AppleUSBXHCI    1.2
com.apple.driver.AppleEmbeddedUSBHost    1
com.apple.driver.usb.AppleUSBHub    1.2
com.apple.driver.usb.AppleUSBHostCompositeDevice    1.2
com.apple.driver.AppleDisplayCrossbar    1.0.0
com.apple.iokit.IODisplayPortFamily    1.0.0
com.apple.driver.AppleTypeCPhy    1
com.apple.driver.AppleThunderboltNHI    7.2.81
com.apple.driver.AppleT6000PCIeC    1
com.apple.iokit.IOThunderboltFamily    9.3.3
com.apple.iokit.IOPortFamily    1.0
com.apple.driver.ApplePIODMA    1
com.apple.driver.AppleT600xPCIe    1
com.apple.driver.AppleMultiFunctionManager    1
com.apple.driver.AppleBluetoothDebugService    1
com.apple.driver.AppleBCMWLANCore    1.0.0
com.apple.iokit.IO80211Family    1200.13.0
com.apple.driver.IOImageLoader    1.0.0
com.apple.driver.AppleOLYHAL    1
com.apple.driver.corecapture    1.0.4
com.apple.iokit.IOAVBFamily    1200.18
com.apple.plugin.IOgPTPPlugin    1200.91
com.apple.driver.AppleEthernetAquantiaAqtionPortMonitor    1.0.0
com.apple.driver.AppleEmbeddedPCIE    1
com.apple.driver.AppleGPIOICController    1.0.2
com.apple.driver.AppleFireStormErrorHandler    1
com.apple.driver.usb.AppleUSBHostPacketFilter    1.0
com.apple.driver.AppleMobileApNonce    1
com.apple.iokit.IOTimeSyncFamily    1200.91
com.apple.driver.DiskImages    493.0.0
com.apple.iokit.IOGraphicsFamily    598
com.apple.iokit.IOBluetoothFamily    9.0.0
com.apple.driver.AppleSSE    1.0
com.apple.driver.AppleSEPKeyStore    2
com.apple.driver.AppleUSBTDM    556
com.apple.iokit.IOUSBMassStorageDriver    243
com.apple.iokit.IOPCIFamily    2.9
com.apple.iokit.IOSCSIBlockCommandsDevice    492
com.apple.iokit.IOSCSIArchitectureModelFamily    492
com.apple.driver.AppleRSMChannel    1
com.apple.iokit.IORSMFamily    1
com.apple.driver.AppleLockdownMode    1
com.apple.driver.AppleIPAppender    1.0
com.apple.driver.AppleFDEKeyStore    28.30
com.apple.driver.AppleEffaceableStorage    1.0
com.apple.driver.AppleCredentialManager    1.0
com.apple.driver.KernelRelayHost    1
com.apple.iokit.IOUSBHostFamily    1.2
com.apple.driver.AppleUSBHostMergeProperties    1.2
com.apple.driver.usb.AppleUSBCommon    1.0
com.apple.driver.AppleSMC    3.1.9
com.apple.driver.RTBuddy    1.0.0
com.apple.driver.AppleEmbeddedTempSensor    1.0.0
com.apple.driver.AppleARMPMU    1.0
com.apple.iokit.IOAccessoryManager    1.0.0
com.apple.driver.AppleOnboardSerial    1.0
com.apple.iokit.IOSkywalkFamily    1.0
com.apple.driver.mDNSOffloadUserClient    1.0.1b8
com.apple.iokit.IONetworkingFamily    3.4
com.apple.iokit.IOSerialFamily    11
com.apple.driver.AppleSEPManager    1.0.1
com.apple.driver.AppleA7IOP    1.0.2
com.apple.driver.IOSlaveProcessor    1
com.apple.driver.AppleBiometricSensor    2
com.apple.iokit.IOHIDFamily    2.0.0
com.apple.driver.AppleANELoadBalancer    7.104.3
com.apple.driver.AppleH11ANEInterface    7.104.2
com.apple.driver.IODARTFamily    1
com.apple.AUC    1.0
com.apple.iokit.IOSurface    352.0.3
com.apple.iokit.IOAVFamily    1.0.0
com.apple.iokit.IOHDCPFamily    1.0.0
com.apple.iokit.IOCECFamily    1
com.apple.iokit.IOAudio2Family    1.0
com.apple.driver.AppleIISController    300.1
com.apple.driver.AppleAudioClockLibs    300.1
com.apple.driver.FairPlayIOKit    71.3.0
com.apple.driver.AppleARMPlatform    1.0.2
com.apple.iokit.IOSlowAdaptiveClockingFamily    1.0.0
com.apple.iokit.IOReportFamily    47
com.apple.security.quarantine    4
com.apple.security.sandbox    300.0
com.apple.iokit.IOStorageFamily    2.1
com.apple.kext.AppleMatch    1.0.0d1
com.apple.driver.AppleMobileFileIntegrity    1.0.5
com.apple.iokit.CoreAnalyticsFamily    1
com.apple.security.AppleImage4    5.0.0
com.apple.kext.CoreTrust    1
com.apple.iokit.IOCryptoAcceleratorFamily    1.0.1
com.apple.kec.pthread    1
com.apple.kec.Libm    1
com.apple.kec.Compression    1.0
com.apple.kec.corecrypto    14.0
** Stackshot Succeeded ** Bytes Traced 78661 (Uncompressed 302528) **
12 (edited by trubadix 2023-11-20 00:57:31)
Oder hier noch mal.
panic(cpu 1 caller 0xfffffe001fd19cbc): Kernel data abort. at pc 0xfffffe002200c560, lr 0xfffffe00220a0cbc (saved state: 0xfffffe84031837d0)
      x0:  0xfffffe1b428b9c00 x1:  0xfffffe201152e430  x2:  0x00000000e00002eb  x3:  0x0000000000000000
      x4:  0x40f3fe002200c53c x5:  0x0000000000000000  x6:  0xfffffe001eae62c0  x7:  0x000000038dade5e9
      x8:  0xfffffe1b428b9c08 x9:  0x00000000e0005000  x10: 0x0000000000800000  x11: 0x0000000000000000
      x12: 0x0000000000000000 x13: 0xfffffe0026bca830  x14: 0x0000000000000000  x15: 0xffffffffffffffff
      x16: 0x40f3fe002200c53c x17: 0x000000000000e90c  x18: 0x0000000000000000  x19: 0xfffffe29a857d900
      x20: 0xfffffe200fcd4280 x21: 0x0000000040000001  x22: 0x0000000000000000  x23: 0x0000000000000000
      x24: 0x80b57e00210d3a68 x25: 0x0000000000000000  x26: 0xfffffe29a857d900  x27: 0xfffffe0022b80c18
      x28: 0xfffffe1b44177538 fp:  0xfffffe8403183d20  lr:  0xfffffe00220a0cbc  sp:  0xfffffe8403183b20
      pc:  0xfffffe002200c560 cpsr: 0x80401208         esr: 0x96000047          far: 0xfffffe1b428b9d5c
Memory ID: 0x6
OS version: 23B81
Boot session UUID: 948089FB-6226-4AE0-A32E-0DC63B7205EF
secure boot?: YES
roots installed: 0
KernelCache slide: 0x0000000016f78000
KernelCache base:  0xfffffe001df7c000
Kernel slide:      0x0000000016f80000
Kernel text base:  0xfffffe001df84000
Kernel text exec slide: 0x00000000184a0000
Kernel text exec base:  0xfffffe001f4a4000
mach_absolute_time: 0x38dc2390d
  Boot    : 0x655a9d3c 0x00067b64
  Calendar: 0x655a9fb0 0x000e7c7f
Zone info:
  Zone map: 0xfffffe1010648000 - 0xfffffe3010648000
  . VM    : 0xfffffe1010648000 - 0xfffffe14dd314000
  . RO    : 0xfffffe14dd314000 - 0xfffffe1676cac000
  . GEN0  : 0xfffffe1676cac000 - 0xfffffe1b43978000
  . GEN1  : 0xfffffe1b43978000 - 0xfffffe2010644000
  . GEN2  : 0xfffffe2010644000 - 0xfffffe24dd310000
  . GEN3  : 0xfffffe24dd310000 - 0xfffffe29a9fdc000
  . DATA  : 0xfffffe29a9fdc000 - 0xfffffe3010648000
  Metadata: 0xfffffe8fe1dec000 - 0xfffffe8fe9dec000
  Bitmaps : 0xfffffe8fe9dec000 - 0xfffffe8ff9dec000
  Extra   : 0 - 0
  Zone    : kalloc.type7.512
  Address : 0xfffffe1b428b9d5c
  Submap  : GEN0 [0xfffffe1676cac000; 0xfffffe1b43978000)
  Metadata: zid:273 inl:1 cl:0x0 0x0000 0x00000000 0xf86d0a2d 0x00016b4a
TPIDRx_ELy = {1: 0xfffffe1b44d05828  0: 0x0000000000000001  0ro: 0x0000000000000000 }
CORE 0: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8403147ef0
CORE 1 is the one that panicked. Check the full backtrace for details.
CORE 2: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8402b7bef0
CORE 3: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8402ef3ef0
CORE 4: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8404577ef0
CORE 5: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8402bb7ef0
CORE 6: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8403473ef0
CORE 7: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8403413ef0
CORE 8: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe84035cfef0
CORE 9: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8403e63ef0
CORE 10: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe84033fbef0
CORE 11: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe84017a3ef0
CORE 12: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8402797ef0
CORE 13: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe840135fef0
CORE 14: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8404127ef0
CORE 15: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8402e9fef0
CORE 16: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8403f17ef0
CORE 17: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe840453bef0
CORE 18: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8402dafef0
CORE 19: PC=0xfffffe001f538620, LR=0xfffffe001f538620, FP=0xfffffe8404433ef0
Panicked task 0xfffffe2010479048: 0 pages, 908 threads: pid 0: kernel_task
Panicked thread: 0xfffffe1b44d05828, backtrace: 0xfffffe8403182f00, tid: 18172
          lr: 0xfffffe001f4fd5e0  fp: 0xfffffe8403182f90
          lr: 0xfffffe001f64836c  fp: 0xfffffe8403183000
          lr: 0xfffffe001f6467e8  fp: 0xfffffe84031830f0
          lr: 0xfffffe001f4abaa4  fp: 0xfffffe8403183100
          lr: 0xfffffe001f4fcebc  fp: 0xfffffe84031834b0
          lr: 0xfffffe001fd0f260  fp: 0xfffffe84031834d0
          lr: 0xfffffe001fd19cbc  fp: 0xfffffe8403183650
          lr: 0xfffffe001f6481c8  fp: 0xfffffe84031836c0
          lr: 0xfffffe001f646a9c  fp: 0xfffffe84031837b0
          lr: 0xfffffe001f4abaa4  fp: 0xfffffe84031837c0
          lr: 0xfffffe00220a0cbc  fp: 0xfffffe8403183d20
          lr: 0xfffffe00210d3b54  fp: 0xfffffe8403183d50
          lr: 0xfffffe001fc112b8  fp: 0xfffffe8403183dc0
          lr: 0xfffffe00210d39d0  fp: 0xfffffe8403183df0
          lr: 0xfffffe001f55e3fc  fp: 0xfffffe8403183e30
          lr: 0xfffffe001f55f45c  fp: 0xfffffe8403183f20
          lr: 0xfffffe001f4b4ed8  fp: 0x0000000000000000
         com.apple.driver.usb.AppleUSBCommon(1.0)[7360CCED-F410-3A3C-BF7C-3E5812B3BC99]@0xfffffe00210d0150->0xfffffe00210d500b
         com.apple.iokit.IOUSBHostFamily(1.2)[9D76404F-181D-3643-875F-D82739B01CC4]@0xfffffe0022005a00->0xfffffe00220b7347
            dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[B562E2F2-059F-3F75-9A50-57B08E283880]@0xfffffe0020a12820->0xfffffe0020a428eb
            dependency: com.apple.driver.AppleSMC(3.1.9)[F86184CF-3AA6-3E13-83DA-E7B4B8977DD8]@0xfffffe0020c1c170->0xfffffe0020c40b33
            dependency: com.apple.driver.usb.AppleUSBCommon(1.0)[7360CCED-F410-3A3C-BF7C-3E5812B3BC99]@0xfffffe00210d0150->0xfffffe00210d500b
            dependency: com.apple.driver.AppleUSBHostMergeProperties(1.2)[D4A08E8E-0BED-3B61-AF9D-6D540D16FE52]@0xfffffe0022167950->0xfffffe002216847b
last started kext at 515783002: com.apple.driver.AppleActuatorDriver    7400.42 (addr 0xfffffe001e1e7eb0, size 7177)
loaded kexts:
com.binaryfruit.driver.SATSMARTDriver    0.10.3
com.apple.AUC    1.0
** Stackshot Succeeded ** Bytes Traced 78299 (Uncompressed 301232) **
Ich weiß nicht, ob es hilft, das Problem einzugrenzen. Aber wenn nicht, wäre es nett mit zu sagen was sonst zu tun ist. Ich verzweifle hier mit dem Interface! Ich hatte noch nie derartige Probleme mit RME.
13 (edited by trubadix 2023-11-26 17:42:15)
Ok, two cables and dozens of searches for the possible cause of the problem later I still get some problems. The crashes seem to have disappeared now (at least for two days of leaving the computer on). I still had a few crashes with the last USB 3 cable which is 5 meters long. I then tried a 5m active USB 3 extension and a very short cable after that. Now, there is a problem, which is exactly reproducible: When I switch on the Madiface XT after the computer was on, the interface is shown as a USB 2 device in "Fireface USB Settings" (I guess it should not be called Madiface XT setting instead, but that what the app is called after installing the correct drivers for device ...). When I switch on the computer after the device on, it shows as USB 3 device as expected.
I also get some drop outs when starting Total Mix or plugin in some USB devices. Is there any hint which cable I might be looking into? I need one with at least 4m length.
I have found out some more things, which I also posted in another thread here about USB 3 cable length:
1) Every cable (down to 2m) I plug into the Mac Studio's own USB 3 Port shows me the Madiface as a USB 2 Interface (I have to reboot, then it's ok). When I plug it into the the USB-port of the Caldigit Thunderbolt 4 hub (with USB 3 ports), that problem does not occur.
2) In every case I get a small audio drop out when switching on Total mix FX. If this only happened for this incidence, I would be fine with it. However, I have never noticed anything like that before and that is why I don't trust it ... I might be wrong, however, and this is just normal on Macs due to some USB security or whatever!
3) However, with the USB-Port from the Hub, I get occasional glitches in audio when listening to longer pieces of music. And at least with the longer cable. But it could also be with the shorter ones, I would have to listen longer to wait if something happend ...
Ok, unfortunately, my journey is still not over yet ... after buying this 5m USB extension ...
https://www.amazon.de/gp/product/B007B6 … 8&th=1
... and this USB 3 cable ...
https://www.amazon.de/gp/product/B07F6R … 8&th=1
it looked good on first sight, but in the end I experienced dropouts again.
How I could get rid of those was only by using exclusively the Madiface XT on my thunderbolt 4 Hub (which I bought for a lot of money to accommodate three SATA SSDs in USB enclosures and other USB devices ). The Mac Studio USB A ports don't work properly with the RME interface!
I have two questions to hopefully end this madness:
1) Do you have any recommendation for a Thunderbolt 4 to USB 3 Adaptor or Hub that I could get for just the Madiface XT? It is actually a waste of bandwidth to use a full thunderbolt port for just a USB 3 interface, but I can spare one port! But I have no clue what adaptor/hub to use that will hopefully not induce more problems with the audio interface? And I was hoping I would not have to buy a pretty expensive hub that is actually built for more than one port ... the alternative would be to get a PCIe expansion chassis to house the Sonnet USB 3 card that previously worked so well with the Madiface XT on my Hackintosh (I see the irony, yes!). But that also seems quite wasteful to me ...
2) Is there any way to troubleshoot quicker? My problem is, it sometimes takes multiple days until some dropouts come back. And I need to be able to quickly test whether a certain configuration induces problems. I don't know for a fact, but shouldn't a massive load on the interface (e.g. a DAW project playing back audio on all (or many) channels make any instability of the USB connection apparent immediately? It would be good to know any way of deciding within a short timeframe wether a certain setup does work or doesn't ...
There seems to be major problems with the USB type A ports on the Mac Studio, I have not seen these to be working for audio devices at all. You can use the TB4 ports as USB 3.0 type C connections with an Apple adapter or a simple USB3 cable (type B to type C) and that should work fine.
