Topic: Babyface Pro (Not FS) recent Linux No sound after suspend and wake
I used Debian linux with kernel 5.10.
It works fine with Babyface Pro (not the FS version).
But when kernel version is upgraded to 5.15 or higher, I begin having an issue where if I suspend the machine, or restart, Babyface Pro does not produce any sound. It is recognized as a device still, etc, and sound is simply no longer produced in the output.
If I plug off USB cable and re-insert, then it works fine again. It is a work-around but but this isn't a great solution.
I am not sure which exact kernel version caused this different behavior, but I can point that it is kernel version difference. I wonder what the solution is and also wondering if there is anybody else using Babyface Pro (not the FS version) using Linux with more recent version who isn't experiencing this issue.
Re: Babyface Pro (Not FS) recent Linux No sound after suspend and wake
I am seeing the same problem on Fedora 40 with kernel 6.8 with Babyface Pro FS. I know you asked for non FS version but seems to be the same problem.
Thank you for confirming that it happens even with the Babyface Pro FS version!
I've been plugging on and off the USB cable every restart / sleep+wake and by having the USB hub right next to my keyboard to make this process easier, but certainly not ideal.
This started having issues somewhere after Linux kernel version between 5.10 and 5.15.
I ended up buying USB TOSLink output and connected the optical audio cable to BabyFace's optical input.
I am running Babyface in a standalone mode, where USB cable is connect to a power but not the any computer.
And I did adjust input levels and pressed the "mix" button on Babyface Pro and audio is sounding great, so I can still use it as an excellent D/A converter, which is mostly what I use the device for anyway.
Any chance to get this fixed? My Babyface pro fs seems to 'stuck' after suspend, even reboot does not fix it - only physically replugging, which is ridiculous.
i was wondering. how did you get the babyface pro fs to work using linux?
CC mode
