Topic: Babyface Pro (Not FS) recent Linux No sound after suspend and wake
I used Debian linux with kernel 5.10.
It works fine with Babyface Pro (not the FS version).
But when kernel version is upgraded to 5.15 or higher, I begin having an issue where if I suspend the machine, or restart, Babyface Pro does not produce any sound. It is recognized as a device still, etc, and sound is simply no longer produced in the output.
If I plug off USB cable and re-insert, then it works fine again. It is a work-around but but this isn't a great solution.
I am not sure which exact kernel version caused this different behavior, but I can point that it is kernel version difference. I wonder what the solution is and also wondering if there is anybody else using Babyface Pro (not the FS version) using Linux with more recent version who isn't experiencing this issue.
