Topic: Linking Fireface 800 to Symphony i/O by Adat.
Hi
I have gone through some Old Postings on this Topic and was hoping you could direct me to the Video that you posted on this subject.I will post the Original Forum answer below,where you mention the Video.
Dave Nolan.
Re: Using Fireface 800 as ADAT with Apogee Symphony
Yes, the WC is required here. Once the setup works with the FW connection, you can save it for standalone operation. To get the signal where you want it, i.e. at the ADAT outputs, route signals from the analog inputs of your choice to the ADAT outputs in the FF mixer. The tutorial video I posted a link to will explain this. Once this works, and you see the input signal at the physical ADAT outputs in the FF mixer, the rest is a matter of the configuration of the Apogee and your audio software.
