Topic: Multiface 1 Adat in not working
I have been  using an additional AD for years and suddenly I thought it stopped working.
But in fact it seems to be the Multiface.
If I do a Loopback Test with SPDIF it works fine. If I switch the SPDIF Operation off for in and out I get no lock for ADAT.
I reinstalled Drivers still same Problem.
Any ideas?
Re: Multiface 1 Adat in not working
You also did a loopback test with the adat cable ?
M1-Ventura, Madiface Pro, Digiface USB, Babyface silver
What's the ADAT source? Have you also tried another cable?
thanks for your replys.
I did the Loopbacktest with the optical cable.
Signal and synch lock did work fine for SPDIF.
So I did not try another Cable so far.
Adat Loopback with the Cable does not work.
I do not get a lock with the external unit and loopback.
The source unit is a Behringer ADA8200.
The setup has worked fine for a long time.
Are you saying optical spdif works and adat not? Then it is not the optical receiver that is faulty afaik.
Correct, this makes it so confusing
Just to be sure, both input and output for optical are set to adat, clock to 44,1k internal? tried 2 cables at least? Adat has a 4 times higher transfer speed I think, so might be more sensitive to cable breaks
Settings were correct. I ordered a Cable .. The idea with the higher Bandwith came to my mind this morning also
thx
