Topic: I can´t change the volume
Hi everyone,
I have been having a problem for a while now. When I turn the volume potentiometer, no matter if it is on main out or phones, the volume does not change. It makes a feint, but stays at the same volume.
The only option I have is when I press vol and it is on the linked screen, then, if I press encoder 1 and turn that wheel, then I can change the main out volume and the same happens with the phones volume if I use encoder 2, but I can't regulate the volume as before, just using the volume potentiometer.
Any suggestions?
Thanks in advance
