oli77sch wrote:rua1225 wrote:Thank you for replying, but I've tried both CC and PC mode and they both didn't work.
Anyway let it set to PC mode because CC doesn’t work on Windows!
When you plug in the Babyface, are there some LEDs lights active?
Do you use an additional power supply or USB power only?
What kind of USB port is it on the computer (form factor USB-A or C, protocol USB 2.0, 3.0 …)? Have you tried different ports?
Different cables? Even a hub?
Maybe also try to reinstall the driver.
Alright, I will try again in PC mode. I don't know how to check the additional power supply or USB power status.
I have tried different USB ports (2.0, 3.0, 3.1) using the official Type-A cable provided. I believe the issue is not with the hardware, but rather with the driver.
After installing the driver, the device does not appear in the system. Normally, there should be a Fireface icon in the taskbar, and it should also show up in my DAW, but it's not happening.
