Topic: RME UFX Durec not working
I've had my UFX since new and Durec used to work fine.
I've had the power supply replaced a couple of times. I'm not sure if firewire works or not as I use it with USB (though I recall I may have had problems with Firewire in the past)
When I try to record now, the drives (tried with an identical drive to what I used to use and a Sandisk USB stick) the files always record silence or full scale (depending on channel) and the files always come up as 18 channel 32 kHz regardless of how many channels I record, and the file name is always messed up on the UFX.
The below screenshot is for a 4 channel recording.
The drives are formatted as FAT32 with 32k cluster sizes.
The UFX has the latest updates installed. I'm running Win10 Pro (though that shouldn't matter)
Can anyone help or suggest what might be wrong with it that I can pass on to a tech to get it fixed.
