Topic: Unable to connect Babyface Pro to Macbook Pro
I have a Babyface Pro and have been using it for years with no issues on a PC.
I recently purchased a Macbook Pro M3 and have not been able to get the Babyface Pro to work on this new computer.
Here are some of the configuration items:
Mac OS upgraded to Sequoia 15.0.1
Upgraded the firmware in the Babyface pro to the latest using my PC.
Installed the Driverkit drivers multiple times (never saw an Accept button to press)
Purchased an external power supply for the Babyface pro
Purchased a USB C/A adapter.
The Babyface Pro shows up fine on the PC and is not recognized on the Mac.
The only way I can get the Babyface pro to be recognized as a sound device on the Mac is by changing the mode of the device by pressing the select and dim buttons (while USB is unplugged). The device then is recognized by the Mac, however the Fireface USB Settings application disappears in this mode.
When I put the mode back to the settings that work on the PC, the Babyface Pro is not recognized by the Mac and the Fireface USB Settings application shows up again (showing Firmware V206 Driver: v4.16).
In either case, the totalmix fx application always shows disconnected.
Can someone at RME shed some light on how to get this configuration to work properly.
Thanks.
