Topic: Raydat + 9652 issue
Hi there,
I'm having an issue that I would need some help for.
I've upgraded computer & soundcard with RME Raydat a while back, all working great.
I still had my old 9652 PCI (not PCIe) and figured out it could be working together with my system to increase my I/O capacity.
Used a PCI to PCIe adapter, and it actually works great, both cards are recognized well and all seems to be good to go.
ADAT I/O's all good, wordclock all good, but the SPDIF of the 9652 doesn't seem to work.
If I plug the same breakout cable to the Raydat, all is green, but connected to the 9652, no sync and no data is going through.
I know it's a bit of an odd setup, but rather than buying new products, if old ones can still work I'm keen to do so.
Tried to fiddle around with the settings, but nothing seems to work here.
Is there anything I should know, is there any hardware limitation or something I'm doing wrong here.
All drivers up to date, and really tried to switch from one card to another with the exact same cables and breakout adapter. On one it will totally work and on the other not at all.
Thanks for your help
