khollister wrote:
Also using the kernel driver because the driverkit version had occasional dropouts/crackles. If RME can't get to the bottom of this, we are going to have expensive boat anchors when Apple finally blocks kernel extensions.
Yep, same thing, never got the new driverkit drivers to work at all, and the previous driverkit version had plenty of dropouts and static bursts through playback. On the latest kernel extension and everything seems to be fine for now, but not excited for what the future holds.
### device
Babyface Pro
Firmware v206
Driver: V4.16
### set up
connected via 1. USB cable. 2. with a hub
M3 Macbook Air
OS: 15.1
### issue experienced
FireFace USB Setting works and shows the Properties for Babyface Pro
TotalMix fails to show mixer or matrix window
CC Mode works so we can rule out the USB cable.
I hope the next driver fixes the issue.
703
There is no issue -> Enable microphone for TotalMix.
Hi mr. Carstens,
You seem to be very confident stating that there are no issues.
Well, unfortunately I have a lot of issues. Hiccup's and stuttering when starting playback from selected regions within a cycle loop. Jumping back to beginning of the cycle although I start from a region on a different point in the cycle.
Ok...question: you say "enable microphone for Totalmix". Now I can see that I enabled it for Logic but there is no option for enabling this for Totalmix in Privacy and Security settings. How would I make Totalmix visible in this menu?
Thank you in advance.
MacBook Pro M1 Pro / 16 GB /1 TB
Logic Pro 11.0.1
Sonoma 14.7
UCX II connected directly to Mac usb-c port/Kernel driver v.3.33 / Firmware v106 (Latest Driverkit was even worse)
705 (edited by waedi 2024-11-03 16:45:51)
notermans wrote:
Hi mr. Carstens,
Logic Pro 11.0.1
Sonoma 14.7
Enable Totalmix for Microphone is only need for Babyface Pro, you have UCX ll.
Bahavior of starting playback the cycle at the beginning is normal.
Otherwise switch off "cycle". Or right-click the play-button and change the settings. Deselect play start from cycle, select playback  from last locator position.
What you can test, in the Audio-Midi-Setup create an aggregate device including the UCX only, then select in Logic this aggregate device as audio device.
Also upgrade MacOS to Sequoia and install new RME driver 4.16 and keep buffer size in Logic to something normal, let's take 128 or 256.
Thanks for your response Waedi,
I have always been doing starting playback from activated region somewhere in a cycle region without hiccups before Sonoma. So I don't agree with your statement that this is normal behavior.
Upgrading to Sequoia not yet due to unsupported plugins.
I will try your tip with AMS setup and aggregate device though.
Thanks again, Huub
707
The Logic update to version 11.0.1 probably did reset the navigation settings in Logic.
Hiccups and stuttering of course is a different story.
In Logic where the playback starts, jumping at the beginning of a loop or just everywhere at the locator position has nothing to do with the audio interface it's just your DAW configuration. Right-click onto the play button will solve this.
708 (edited by khollister 2024-11-08 14:47:29)
So I tried 4.16 with the latest MacOS Sequoia and while everything appeared to go smoothly and Fireface USB indicated 4.16, The UFX III did appear in AudioMIDI as an audio device and TotalMix would not display. Went back to 3.33 and everything is working again.
Well except that with Sequoia, I can't change buffer sizes in either Logic 11 or Cubase 14 once a VI is loaded. The DAW audio engine is dead unless I close the DAW and restart. If I change the buffer before loading any VI's it works but once a VI is loaded, alll,bets are off.
And, yes, the FW is up to date on the UFX III
Sample rate change works fine if I use the Apollo as the audio interface
709
Use the UFX III within an Aggregate Device and select that Aggregate Device in Cubase/Logic. Works?
Nope - same issue. Once I instantiate a VI, changing the buffer kills the audio. Sometimes removing the VI(s) will restore it but sometimes it requires restarting the DAW
711 (edited by khollister 2024-11-08 17:58:15)
And 4.16 still will not work on MacOS 15.1 The UFX III shows up as a USB device in System Report and the Fireface USB app seems to work, but there is no MacOS audio device.
I must say I'm really disappointed in the supposedly bulletproof RME drivers. This thing is way more problematic than any of the Apollos I have owned.
UPDATE:  Tried connecting the UFX III to my MacBook Pro still on Sonoma. DK 4.16 seems to work correctly - I see the UFX as a MacOS audio device.
712 (edited by dayjob111 2024-11-08 18:44:30)
so, just looking around to see what's cooking with sequoia. still on sonoma and have no issues. seems like a bad time to update. better to wait for a new driver version from RME that is 100% shaking hands w/sequoia. I'm running a UFX+ and the driver kit driver. i forget what version but it works.
713 (edited by waedi 2024-11-08 19:30:32)
There is a hidden ON / OfF switch in the MacOS Sequoia :
System Preferences / General / startup-items and Extensions :
Scroll down to the Driver Extension RME, see right end there is a small icon a circle with an i, this is a button, click it, may be a On / OFF switch reveals.
SUCCESS! Did I mess this little tidbit in the install instructions? (I think I read them like 3 times). And I can now change buffer size at least in Logic (haven't tried Cubase yet). So far no sign of the random clicks/pops I was getting with an earlier version of DK under Sonoma. Time will tell on that.
Thanks!!
715 (edited by maggie33 2024-11-08 21:54:11)
So - does it appear in AMS or not? Looks like you did not install the DK drivers properly.
The DK works on sequoia here (and afaik for 99% other users in this forum) without problems.
Its all documented how to install the DK driver on the RME Website (and multiple times here in the forum).
And it is also documented by apple what changed.
Sequoia:
https://support.apple.com/en-ng/guide/m … 0/mac/15.0
And compare this with Sonoma:
https://support.apple.com/en-ng/guide/m … 0/mac/14.0
Edit: I sent my post in meanwhile you updated your state.
“Do It For Her”
716 (edited by khollister 2024-11-08 21:59:53)
I just read the install instruction in the 4.16 README again - no mention of the setting @waedi told me about. I looked in the download and support sections of the website and didn't see any other Sequoia instructions.
Sequoia:
so the driver kit and the kernel extension both work fine in Sequoia for most people?
718 (edited by khollister 2024-11-08 22:13:22)
Sequoia:
The DK driver seems to be working fine for me now. The kext driver works, but changing the buffer size in a DAW when one or more VI's are instantiated locks up the audio system (Cubase & Logic).
719
This thing seems to happen only to a very few users, most of the users just install and it works.
I don't know why this happens, I just can tell from my computer that I have SIP disabled since long ago.
Please tell, is in your computer SIP disabled or not ? It would be done by you, you would know it.
I made the changes in Recovery Mode to install kext's but I did NOT disable SIP via the Terminal command
721 (edited by waedi 2024-11-08 22:46:32)
Thanks for the respond, it's interesting but also even worse.
By any chance you can tell more detail of these changes in recovery mode ?
At least we know about that hidden switch and your interface is working.
And you also understand why driver installing instructions can't cover every users situation ?
SIP disabled or enabled, some changes in recovery mode, no one knows what else settings may have influence on the driver installation - in current MacOS or in upcoming upgrades.
723 (edited by mrck 2024-11-09 07:38:39)
Hi, new RME user here. I just switched to RME from UAD with the new Fireface 802 FS AE and i'm experiencing sporadic glitches and audio drops with computer audio never happened before with Apollo X6. Below my system:
Fireface 802 FS AE
MacBook Pro M1 Max 32Gb RAM
Sonoma 14.7.1
DK 4.16 with the latest firmware on the interface
any workaround or setting to fix this issue? Updating to Sequoia could help? M4? Kernel extension driver?
Thank you
RME Fireface 802 FS AE, Focal Solo6 BE Anniversary, Neumann NDH30
Fireface 802 FS AE
Sonoma 14.7.1
Thank you
This was the exact issue I was having previously with my M2 Ultra Mac Studio and a UFX III using an earlier version of the DK driver with Sonoma. I updated to Sequoia before trying DK 4.16 (you can read my problems with that combo before @waedi suggested the magic fix above).
The one thing I can suggest is to use the RME provided USB cable and connect to one of the USB ports directly on the MacBook, not through a hub or dock, although that seems far more critical with the USB3 UFX III other than USB2 like your 802.
I can say 4.16 and Sequoia 15.1 now appears rock solid so far with no random glitches like I got with Sonoma and earlier DK drivers (it was pre-4.12 but I don't recall the exact version I had trouble with).
In fairness, ny Mac Studio rig is very complex with a Caldigit Element TB hub, multiple USB4 SSD's, a Apple Pro Display XDR with USB devices and a USB hub connected to its USB ports, etc. It may well have been some downstream interaction I never discovered. And using USB3 (I am using the MADI buses in the UFX II to connect an Eventide H9000 so dropping back to USB2 was never an option) certainly increased the odds of having issues.
Kext driver 3.31 or 3.33 were completely trouble free on the Studio with Sonoma however. 3.33 does have some issue with changing buffer sizes in Logic & Cubase with Sequoia 15.1 for me, which is why I was trying to get the DK driver to work.
BTW, I still have my Apollo X8 connected as well and use it via ADAT to the UFX as a hardware FX unit so I can use UAD plugins on live, record-armed VI tracks with minimal latency. Using the plugins in the DAW with the Apollo or UAD Satellite have too much latency to use live. So I use the X8 on the ADAT ports exactly like my H9000 on the MADI ports as external HW FX.
Just to say thanks for your comments. They reassure me in upgrading eventually to 15.1 and one day eventually having to stop using the 3.31 kext I use.
Also I think they point to a complexity in advanced user- or pro- setups that we can't avoid, but don't often get across in this forum as we report the occasional glitch. My setup is similarly complex and similarly sensitive to all the variables and their effect on RME  audio.
I'd definitely appreciate some (RME) KB articles about what is known to work, and things or scenarios that are known to cause issues (like incompatible 3rd party hardware), or which bring uncertainty to the expected stability and performance. Why not even some more in-depth info on stability and scheduling in complex hybrid setups, with the various architectures and drivers on offer.
Fireface UCX, Focusrite OctoPre adat, Sound Devices MixPre-D, Mac Studio M2 Max, macOS 14
I think a big part of the problem in what you (understandably) are requesting is the impracticality of testing all the combinations & permutations of gear. And what we learn from forums like this are largely anecdotal. I'm a bit concerned that there will be another round of learning curve (and associated driver tweaks) with the new TB5/USB ports on the new M4 Pro/Max/Ultra Macs. If anything will slow me up from upgrading to an M4 Ultra Studio next year (other than cost), the RME drivers will be it. That's not intended as a  slam of RME but just the reality of constant evolution of the USB protocol and HW.
Overlooked this? https://rme-audio.de/rme-macos.html
“Do It For Her”
Hi Guys
I've recently bought a Digiface Dante and I'm having issued getting this running on one of my mac's.
I've got a Mac mini M1 running Sonoma 14.1.1, I've managed to allow Kernals etc download latest drivers 3.33, Fireface USB Setting and Total mix both pop up and work fine.
I've got a MacBook Air M1 which ive tried a few different OS now, but currently on Sonoma 14.7.1, I've tried a load of different installs and clears, including a full restore of OS. I've tried the 3.33 divers and also the latest driver kit drivers. Everytime the applications install and appear in the applications folder. But they fail to open and just bounce in the dock a couple of times then disappear.
The latest install of the driver kit drivers gave this error in terminal.
Error Domain=KMErrorDomain Code=31 "Error occurred while building a collection:
Cannot build collection without binaries as only 1 codeless kexts provided" User Info={NSLocalizedDescription=Error occurred while building a collection: Cannot build collection without binaries as only 1 codeless kexts provided}
I'm 3 days in trying to battle with this at the moment and loosing the will, so any help would be very much appreciated.
Thanks, Jake
729
That error message is default, so you can disregard it.
installed Sequoia a few days ago. works fine. didn't have to do anything w/drivers. just installed the MacS update via software update in system settings. no problems w/my RME UFX+. seamless update.
731
Thanks for the report, may you tell how the UFX+ is connected ? With the two Apple dongles ? What Mac is it and wich driver is in use ?
732 (edited by dayjob111 2024-11-18 03:51:09)
sure, Macbook Pro M1 Max connected to a Caldigit TS3 Plus. The UFX+ is connected to the TS3+ via USB. it's the Driver Kit driver. I forget which version it is but i think it's most recent one available from RME. I'm not connected to the studio right now but will check later to confirm driver details.
when i view the extension in finder and show details it's says it's v 1.0.42 and it was installed on september 4th 2024
but i'll double check details when i'm docked in the studio later.
edit: sorry for delay.. forgot about this. **firmware v55, Driver 4.16**
733 (edited by mattrobertson 2024-11-19 20:52:07)
hi!
Im having a weird glitch in Logic Pro most times when I click in the timeline to locate to a new part of the song. If I always hit Stop and then Start, its fine, but if I locate directly (no gap in playback), I notice that the orange microphone icon in the system menu bar flickers off and on, and I get the audio glitches. I moved from the old v3 driver to the DK drivers about a month ago, and I think this issue has come with that upgrade, but I'm not totally sure. When I change driver to macbook pro built in speakers the issue goes away...
Any ideas? Thankyou!
M1, OS 14.7, Logic 11.1
Any ideas?
This has already been discussed in many different threads.
Just use the search function...
ex here:
https://forum.rme-audio.de/viewtopic.php?id=40022
or here:
https://forum.rme-audio.de/viewtopic.php?id=40440
“Do It For Her”
hi maggie33,
with all due respect, yes i did use the search and
- only one of those threads mentions the issue I have and
- no solution is provided, MC just provides a link to disable continuity camera which i did on day one, so that's not it.
If you have any other insight I would love to hear it smile
thankyou
Seems you overlooked, that MC provided 2 links?
Did you read the first one (clocking/sample rate issues)?
With all due respect, it would certainly be more constructive to share the details of your environment and system configuration. Or what things you can rule out.
Rather than sitting back and expecting someone to randomly find the needle in the haystack smile
“Do It For Her”
lol - maggie33, thanks for you response, I certainly do not "sit back and expect" someone else to solve my problems. I mean,... its  not like Im going to stop work for 3 says until someone posts a solution on here right? so funny....
Anyway... yes i did read the posts above, and I guess I should have been more specific, but dont read that as laziness. There has been much, and continuous, trouble shooting at my end. If I find anything useful I will be sure to post back here so other people can find it in the search function.
738 (edited by darkinners 2024-11-22 16:53:12)
I am having some issue with USB connection with my UFX+ that I am pretty sure it's MacOS issue not RME but I am wondering if anyone having the same issue.
1. I was using 14" MacBook Pro M1 Max and after updated to Venture or Sonoma ( I forgot which), starting having random drop out with USB connection when playback YouTube or whatever, I googled every possible solution and the majority of people having this issue claim that it's memory pressure over 60% but in my case even my memory pressure is 4% still having the random drop out issue. that I never experienced before Ventura/Sonoma. The only solution that work for me is to use TB connection instead of USB3.
2. I upgraded to 14" MacBook Pro with M4 Max, which miraculously solved this random drop out issue but there's a new issue arise, when I use USB3 connection with my UFX+ the audio will drop out when I save a file/quit application.
For example while I am playing music on Apple Music or edit photos in Photos app, everything is fine but the moment when I click "done" to save the photo in Photos, the audio will drop a split second, same thing will happen if I quite an app, for example when I play the music and update the UAD plugins via the UA connect APP, everything works but the moment when I "Command + Q" to quit the UA connect app, the audio will drop out a split second, all this is 100% repeatable.
I am wondering if there's something about the CPU management/scheduling issue of MacOS, when the efficiency cores bursted into 100% load and audio will drop out or something to do with the disk write that cause the CPU usage spike and cause audio drop out..
It's infuriating, I never had any of this issues prior to Ventura update...
by the way I am on the latest Sequoia 15.1.1
739
You could try a different USB port, this issue might not be present on all of them. If still there then the next versions of Sequoia hopefully improve this behaviour.
740 (edited by Primativ 2024-11-30 14:26:48)
Hi everyone,
Just bought a UFX III and installing on my M4 MBP which I purchased last week. Installed the driverkit drivers, I can't see the UFX as an option in Abelton as an audio interface. Also Totalmix does now show up at all. It is installed, but when I click to open it, nothing appears. I cannot find the GUI mixer window anywhere.
It is connected via USB3 cable supplied by RME. The host light is lit on the unit, and theFireface USB settings indicates that the UFX III is connected. I am on Firmware V20 and driver v4.17.
Is rthere anyway I can get this working? At the moment the UFX is just a very expensive paperweight....
As a brnd new user of RME this is really frustrating.
I recently tried a UFX 2 on a windows 10 PC which worked fine, so I know how to get these up and running, but on the Mac I am stuck. It simply doesn't seem to work.
741
MacOS system preferences / general / startup items and extensions
scroll down to Driver extensions and click that little i-icon at the end right side.
It may reveal a switch, make sure it is ON.
Thanks, I gave up and downloaded the Kernel drivers and can confirm everything is working as expected now.
It seems there is still some work to do to get the driverkit drivers working for many of us.
743
It's the exact opposite. Due to not needing to set  the unit to lower security (which some fail to do correctly) and the simplified installation process DriverKit is much more easy and popular.
But now that you have KE just stay with it.
I have an issue with the volume control on macOS, and have had for some time.
Setup:
Mac Mini M1 (2020), macOS Sequoia 15.1.1
Fireface UC, Driver 4.17 / Firmware v127
Problem:
After leaving the computer alone for some time, the system-wide Volume control buttons no longer function. No increase and/or decrease. I have to manually go into the TotalMix app and use the AN1/2 slider to control it. Functionality is not restored until I reboot.
This has been happening for a very long time now, over multiple macOS major versions (using M series chips).
I'm not sure if its because the Mac goes to sleep and wakes up, screensaver activates or it just 'breaks' after a certain amount of time.
Anyone have any idea? Have I misconfigured something? Possible bug? Thanks.
No bug.
This behavior has always been exactly as you describe.
The reasons why have been explained in several topics in this forum.
“Do It For Her”
Thanks MC, I moved the UFX+ to another USB 3 port in the OWC TB4 dock, seems really solved this issue! it's really strange, as I understand all 3 USB-A port on the OWC TB4 dock use the same USB chip.
On a new Sequioa laptop, I was not able to get the DK version to work (interface not recognized) without first lowering security, which was unexpected. Was this bad luck/user error, or is that step still necessary for the DK driver?
748
It never was, for DK. There was something wrong, but we will most probably never find out what, now that it works.
maggie33 wrote:
No bug.
I've combed over many threads already and I'm not getting a clear picture as to why.
In any case, killing the TotalMix app and restarting it 're-enables' system-wide, macOS volume control. Surely this isn't a 'feature'?
Seems some interfaces (like UC) were/are possible to do this. But afaik its not the case for the most USB based units.
So, not a 'feature' at all...
“Do It For Her”
