751
Please Help, lots of trouble with latest DK (4.17) and KExt (3.33) drivers
Hi, I'm running on a MacBook Pro (16", 2019) on Big Sur 11.7.10, using a Fireface UCX connected (directly to the MBP, not through hub) in USB, with nothing else on it but a 48v-powered mike and a guitar. UCX outs are directly connected to my studio monitors.
So far I was running quite fine w/ a firmware update that was dating back in 2019 (installed w/ RME USB Series Flash Tool v1.68) and with the Kernel Extension driver v3.19.
Today I:
- First, upgraded the firmware to v49
- Then, tried to install DriverKit v4.17 - which based on install "Read me", is supposed to uninstall existing former K. Ext. (see issues I encountered below)
- Then, tried to install K. Ext. v3.33 - which based on install "Read me", is supposed to uninstall the DriverKit extension (see issues I encountered below)
- Then, tried again several times to re-install either of them on top of my system (running the Fireface USB DK 417.pkg or the Fireface USB 333.pkg file), which switches what driver Fireface USB Settings is reporting when I launch it.
At each stage, the Fireface USB Settings app was reporting the correct version of firmware (49) and of driver (either 4.17 or 3.33). Besides, TotalMix FX was updated to 1.97 upon the very first driver install above.
I get the following issues.
For the first couple of minutes after reboot, all seems file, though the MBP fans run fairly hard upon startup and after.
After 2-3 minutes issues pile up.
Common to DK 4.17 and K.Ext. 3.33
- Total Mix FX starts blinking slightly, as if display of its window was slightly unstable
- Sound out cuts suddenly, and audio out switches to another hardware
- All the system (inclus Finder, system prefs), Apps (all open ones), reaction time to mouse or keyboard actions, gets very sluggish (maybe a little less so with DK 4.17 but still quite, and definitely extremely sluggish w/ KExt 3.33)
- In my DAW (Logic Pro X 10.4.8) audio in gets chopped (sounds like a lot of jitter)
Specific to DK 4.17
- In system prefs/sound, Sound Out display of Fireface UCX stays stable, but in the Sound In pane, the Fireface UCX blinks in & out repeatedly, every few seconds
Specific to KExt 3.33
- In system prefs, when I try  to access the Sound tab, I  get "Preferences Error - Cannot load the Sound preferences window"
- In Logic, can't find any input but Input 1
Once I reach this point, the only way for me to get back to a useable computer (no sluggishness, at least), is to turn it off, disconnect the USB cord of the Fireface UCX, and restart. In other words, my Fireface UCX is now totally useless and I cannot work in my music studio since I no longer have an audio interface up and running.
MY MOST URGENT NEED:
- How can I uninstall both DK 4.17 and all RME KExt that might sit on my system, as well as TotalMix FX, and install back my former KExt driver and version of TotalMix FX which were working just fine (I still have the 2019 install package on my hard drive) ?
Nice to have, but less urgent:
- What should I do to solve the above and run either of the most-up-to-date of DK or KExt driver + version of TotalMix FX flawlessly?
Thanks in advance for your help.
Cheers,
Arnaud
752 (edited by waedi 2024-12-17 16:29:23)
Today I:
Specific to DK 4.17
You may check if Microphone access in the MacOS system preferences / Security and Privacy is enabled for Logic.
For the installation of the Kext driver you may have to disable SIP.
That's what I would try : Disable SIP correctly, then install DK 417, restart computer.
When everything works, you can re-enable SIP.
Hello there,
Just bought a Digiface USB.
Unable to install it on Mac Mini M2 Pro with Sequoia. Install seems to work well, but no "driver" loaded. Looked at some posts here about ktext file. No Ktext file founded.
Able to install it on Macbook Pro with Monterey. I updated the card to v18 there.
Tried to reinstalled several times with no luck. The RME extension is allowed in the extensions.
I am surprised to see terminal commands in a RME forum ... Coming from old multiface it was always rock solid but here I have to admit that I am surprised.
Any help welcome. Thanks in advance.
754 (edited by waedi 2024-12-17 19:22:49)
Driver 417 is what I would install...
And also check :
MacOS : System preferences / General / Startup items and extensions
scroll down to driver extensions and click the littke i-icon right side.
It may reveal a switch to enable the driver...
And also check :
THANK YOU SOOOOO MUUUUCH!!!!
I used the 417 but I was not aware of that little -i-con right side. RME was there, just a click and the card is endly detected. You saved my day!
Your post should be pinned because I think many other users may be stucked like me in the near future!!!!
Thanks again for your so precious help!
Have a great day / night!
756 (edited by waedi 2024-12-17 22:29:23)
This happens with new computers with new installations. Some people buy a new Mac and let migration copy the old computer into the new including all drivers.
It is unclear (to me) why some users with new installation has to enable the driver there and others don't.
Glad you can work.
It is a fresh install. Just that the RME explanations were not so clear as yours. In fact, they even dont talk about that little click to do  at that specific place.
Anyway Mac sucks with all these security restrictions for sure smile
Thanks again, I was getting crazy!
758
Because Apple invented this in one of the last MacOS upgrades not long ago.
Hello, I've updated my Mac (M1) to Sequoia and my Fireface UCX stopped being recognised. It has latest flash update, and I installed the latest driver (4.17). After reboot I see an error that system kit extension forbidden by system policy.
I also don't see 'Allow' button in my mac's security settings (I guess as I clicked it when I was installing the previous drivers)
I don't want to modify security settings, so I'd like to go with DriverKit driver. Is there a way to make it work?
760
Did you check for this thing in post 754 ?
I saw this post - I don't have 'drivers' section there, I have a section called 'Extensions' at the bottom of this screen, which bunch of items, such as Actions, Finder, etc. But I don't see any references to RME there.
Then the DK Driver either isnt properly installed or you missed sth from:
https://rme-audio.de/rme-macos.html
Maybe you missed this?
macOS Sequoia
Before the reboot for finishing the driver installation open System Preferences, General, Login Items & Extensions "Allow in the Background" click the switch to allow the RME GmbH extension.
Install the dk driver again. It should finally look like this:
https://rme-audio.de/files/uploads/Support/macOS-Extensions.jpg
“Do It For Her”
763 (edited by pashtett 2024-12-21 13:32:53)
macOS Sequoia
Thanks, I guess you're right that the driver is not properly installed, as this error appears at the end of driver installation. Any other ideas? Shall my card be unplugged or plugged during the installation?
764
You're sure the UCX is connected via USB (not FireWire)?
765 (edited by pashtett 2024-12-22 00:09:27)
It is connected via USB and it worked fine until I updated my mac os to Sequoia.
I just tried to uninstall the driver and install it again - same story. I have this 'Error loading RME USB
DriverKit extension - Forbidden By System Policy' message at the end of the driver installation. Fireface USB Settings app launches, but when I launch Total Mix I don't see its UI at all however the nav bar says that total mix is running, and Fireface is not recognised by the system
My laptop has some anti-malware software installed, could it be the reason?
766 (edited by maggie33 2024-12-22 01:37:39)
Thats not relevant for the installation process itself...
Possible, but without knowing further details, hard to say, what the cause is...
Lets do a step by step maybe...
1) 100% Sure you downloaded and install the 4.17 Driverkit driver?
Edit:
1.1) Make sure "App Store and identified developers" are allowed in Security Settings:
https://cdsassets.apple.com/live/7WUAS350/images/macos/sequoia/macos-sequoia-system-settings-privacy-and-security-open-app-anyway.png
(This is necessary to be able to install non-AppStore Apps/Drivers - For details see Chapter "If you want to open an app that hasn’t been notarized..." in https://support.apple.com/en-us/102445)
1.2.) Start the DK Installer again.
1.3.) Before finishing/exiting/rebooting (after) the DK installer, go to the Privacy Settings again (see 1.1.) and check if there is the "Open Anyway" Message. Klick on it!
Reboot. If still not works, post results of steps 2) and 3).
Edit end
2) Open a terminal and enter
systemextensionsctl list | grep rme
-3) Have a look into this folder, if you can find the .dext there:
/Library/SystemExtensions/<LONG-UID>/de.rme-audio.dkusb.dext
Please answer your results for these 3 points, so we can look further...
If possible, additionally sharing the relevant screenshots could help to understand...
“Do It For Her”
767 (edited by waedi 2024-12-22 00:46:35)
For unknown reason sometimes applications who need microphone access ( audio input channel access) don't get listet into the microphone access list.
it is possible to add it manually with a terminal code.
This code here is made for adding Cubase 14, it works.
If someone could correct the code for Totalmix ?
#!/bin/bash
sudo sqlite3 ~/Library/Application\ Support/com.apple.TCC/TCC.db "INSERT or REPLACE INTO access VALUES('kTCCServiceMicrophone','com.steinberg.cubase14',0,2,2,1,NULL,NULL,NULL,'UNUSED',NULL,0,1652639195,NULL,NULL,'UNUSED',0);"
exit 0
I'm not programmer, it seems the 'com.steinberg.cubase14' needs to be replaced with something Totalmix, but it has to be exact...
768 (edited by maggie33 2024-12-22 02:11:23)
Waedi, with all respect.
1) This has nothing to do with driver-installer problems at all.
2) I wonder, because you already know, that microphone access for Totalmix is only needed for Babyface Units.
I mean, you are manipulating the users TCC.db directly here via sql statements and sudo rights (both make no sense).
Make sure, you really know 100% what you do, before recommending such system-deep things to others. This can lead to malfunction of the whole environment (especially if you mistype sth or f.ex. forget the "~" character)
Additionally, the TCC.db it is related with Privacy Settings like Microphone Access, etc... but has nothing to do with Apples Gatekeeper mechanism. If you are interested, i recommend to read a good explanation of the TCC.db, which can be found here: https://eclecticlight.co/2023/02/10/pri … nd-doesnt/
“Do It For Her”
769 (edited by pashtett 2024-12-22 20:28:45)
Edit:
Edit end
Hi, thanks for your reply.
At the end of the driver installation I see the error message that I posted above. There's no "Open Anyway" button in Privacy settings afterwards.
The command 2) returns no results, as this folder (from -3) contains no rme files. There's just CrowdStrike Falcon dext, that I suppose could be the reason
Then its clear: The driver is not installed.
Did you try to disable (temporary) your Anti Malware stuff?
Another possibility would be if your Mac is managed by MDM (Company Policies which restrict such installations)?
“Do It For Her”
Yes, it's managed by company policies, so I cannot turn off the anti malware. I tried to use at least 3 different interfaces with this laptop (focusrite, ssl) and this was never a problem, so I just can't get why RME can not make a driver that will just work.
772
Hi, thanks for having replied to my query on Dec 17, and sorry for the late reply, I was off for a while. Basic question, what do you mean by "Disable SIP"? What is SIP?
Sorry for asking such a newly question smile
And thanks for the help!
You should contact your company’s IT support. It’s very possible that their device management policies are preventing install. I’m presuming you’re using the interface for work purposes of course.
Have you tried installing the Focusrite and SSL drivers since Sequoia?
774
Those units might be class compliant...no extra driver, just tools...
775 (edited by waedi 2024-12-23 22:20:20)
Hi Alb
The readme of the driver on the last page describe the procedure.
SIP means System Integrity Protection.
Some software installation needs to disable SIP for the installation. After the installation re-enable SIP.
On my computer I did disable SIP years ago and never had an issue.
Other users don't recommend this.
https://support.apple.com/en-lk/guide/m … 8f7291/mac
776 (edited by waedi 2024-12-23 23:55:57)
Hi Maggie
I agree, such code is not for public, but if you would manage the manipulation to insert Totalmix into the Microphone list, it may would help Nils here : https://forum.rme-audio.de/viewtopic.ph … 46#p229646  He has a Babyface Pro FS on a new M-mac...
777 (edited by maggie33 2024-12-24 07:54:26)
It would save time if you had shared the information earlier.
pashtett wrote:
...so I just can't get why RME can not make a driver that will just work
Believe me or not : the driver will "just" work (as for 99% of the other users), if you will be able to install the RME (or general any other) driver - Or if your company will allow you to do this.
Maybe, to add to MCs Post:
You can set your UCX into CC Mode, too (no drivers needed - but then, no advantage of Totalmix and all the other benefits)...
“Do It For Her”
778 (edited by maggie33 2024-12-25 00:27:44)
Hi Maggie
Hi waedi,
If you are really sure that someone knows to handle Terminal commands, etc... (I am still not sure if Nils does). And if you are sure, it lacks due to the missing Mic does not appear in the Sec Settings, you could do sth like this - No responsibility for nothing:
1) close the settings App (if opened) on Mac
2) Copy the ~/Library/Application Support/com.apple.TCC/TCC.db to (f.ex. ~/Downloads) manually via finder
3) Copy (Back it up) in finder to f.ex ~/Downloads/TCC.bak.db (just in case...)
4) Open Terminal and enter the following command:
sqlite3 ~/Downloads/TCC.db "INSERT or REPLACE INTO access (service, client, client_type, auth_value, auth_reason, auth_version, csreq, policy_id, indirect_object_identifier_type, indirect_object_identifier, indirect_object_code_identity, flags, last_modified, pid, pid_version, boot_uuid, last_reminded) VALUES ('kTCCServiceMicrophone', 'de.rme-audio.TotalmixFX', 0, 2, 4, 1, NULL, NULL, 0, 'UNUSED', NULL, 0, 1735004841, NULL, NULL, 'UNUSED', 0);"
5) In Finder, manually copy (and overwrite) your modified ~/Downloads/TCC.db to the original ~/Library/Application Support/com.apple.TCC/TCC.db
6) Open "Settings/Privacy.../Mic Access" again, and Totalmix (if it was previously installed) but for whatever unusual reason not listed, should now appear (and be enabled) for Mic access.
Edit: Corrected bundle id of TM to: "de.rme-audio.TotalmixFX"
“Do It For Her”
779
Is Grossbuchstaben kein Problem ? TotalmixFx oder TotalmixFX ?
Du hast recht. Tippfehler. Sorry. Bundle IDs sind case sensitive (afaik, zumindest in der TCC.db). Habe meinen post korrigiert.
Ich denke jedoch dieses Thema ist offtopic hier. Kann gerne in einen anderen Thread verschoben werden...
“Do It For Her”
### device
Babyface Pro FS
Firmware v206
Driver: V4.17
### set up
connected via 1. USB cable. 2. with Studio Display
M1 MacBook Pro
OS: 15.2
### issue experienced
FireFace USB Setting works and shows the Properties for Babyface Pro FS
No issues with Logic Pro but looses connection with Reason 13 quite often like 20 times in 3 hours
Reason works fine with the Studio Display as audio device ...
I finally got the recent Driverkit drivers to cooperate, but occasionally on playback with my UFX II I get a quick audio drop-out with a blast that sounds like a zap of electricity. It's very loud and disruptive. Any idea whats going on here?
With the recent kernel extensions I didn't have this issue, but rather very brief bursts of static when skipping through a track/play-pausing and anything that tasks the CPU.
Seems like both drivers have their issues on Sequoia 15.2
